Question about Apple MacBook Mac Notebook
Emac start up problem - Apple MacBook Mac Notebook
  • Apple Expert
  • 481 Answers
Sorry, but this problem statement is incredibly non-specific, and not at all conducive to any reasoned diagnosis. Here is what I can offer:
Be aware that certain models of eMac were built with a specific lot of faulty Taiwanese capacitors (http://en.wikipedia.org/wiki/Capacitor_plague), and with age may begin to exhibit problems with startup and/or faulty video. The extended warranty on this problem has already expired. If the tops of the capacitors visible inside the access door on the bottom of your eMac are bulged or leaking similar to those in this image:
your only recourse is to look for a replacement for your eMac.
Posted on Nov 01, 2010
Need to transfer data from old computer to new computer
You have a bad situation. Only a mac repair pro can help you in this case as it's hard to arrange some tools to solve the problem. A pro can gain access to your emac hard drive and free up some space or transfer your data using special tools and knowledge. Thank you and good luck.
Mac Repair Mississauga Apple MacBook screen repair Service MacBook pro...
Oct 17, 2014 | Apple eMac Desktop
Have apple eMac forgot user password can you help
You need to start up from the system cd for the eMac then use 'Password Utility' to change the password.
Alternatively, if you are transferring the files to another Mac, you can start up the eMac in 'Target Disk' mode by holding down the 'T' key during start-up until a Firewire symbol appears on the screen. The computer can then be connected to another Mac which will see the eMac as an external HD.
Apr 20, 2014 | Apple eMac Desktop
I bought a eMac from the dep of Education and I am unable to get into it because i don't have the username or password
You should format the internal hard disk and install a clean and fresh version of Mac-OS anyways and create a new user-account. If there is no install-disc included, try calling Apple, tell them your eMac's serial number (All eMac's have their serial numbers printed inside the disc drive door), and ask them if they have any replacement install discs for your model of eMac. Check out the Apple eMac support page or the Apple eMac support forum for more informations.
Jun 23, 2010 | Apple eMac G4 Desktop
I have an eMac and would wireless USB adapter to work
It depends on which eMac you have. The 1/1.25 Ghz and the 1.42 ghz models have USB 2.0 so either adapter will work. The slower speed eMacs only had USB 1.1 and will not work for those types of adapters. The 700/800Mhz models will use the original AirPort card while the rest of the eMacs use the Airport Extreme cards.
Dec 30, 2009 | Apple eMac G4 Desktop
After starting my emac a screen comes up asking me to log in above it says darwin/bsd (user-s-emac-2.local) (console)
Sounds like some of your system files may have been corrupted. Restart your computer with you OS disc, and when it launches, go to the top menu and look for "Disk Utilitiy". Launch and see if you can repair the files that way. If not you may have to reinstall the system software. If so, choose the option that won't erase your info on your drive.
Last resort is to wipe the drive clean and reinstall the OS fresh, but this will erase everything.
Before erasing everything, if you have access to a second mac, you can connect the emac to the other mac via a firewire cable, turn on your emac in hard drive mode by starting it while holding down the "T" key. You'll get a firewire icon on the screen. Then turn on the second mac... you can off load any files to the second mac and then reinstall the OS via the OS discs.
Best of success.
k
Sep 18, 2009 | Apple eMac 1.2GHz 256 40GB Combo Drive -...
Emac g4 1.25GHZ 256 wont read hard drive or cd drive
I take it you just get a grey screen and spining wheel when you try to start up
Aug 12, 2009 | Apple eMac G4 Desktop
EMac stuck on loading screen
Well i don't know of a fix for the issue u have, but i do have a tip and you might be able to fix the issue you have this way as well. But if you plan on transfering files from one mac to another esp. if one is either an older mac or a portable. you would always want to make one or the other a target disk instead of two stand alone mac's.
Why, because your eMac's older and the data transfer might be failing or can't process the data fast enough to get broken down to bits to be put back on the other end thru the cat5 line. But to transfer files of over 1 GB i would recommend you start the iBook in target disk mode. But since your eMac is the one with some issues put the eMac as the target.
To connect two mac using TDM (Target Disk Mode) you will need to get either a 6-pin IEEE to 6-pin IEEE firewire 800 cable, a 6-pin IEEE to 9-pin IEEE firewire 800 cable, or a 9-pin IEEE to 9-pin IEEE (if your eMac has a 9-pin port) firewire 800 cable.
Then you connect the cable to one of the eMac's 6 or 9 pin ports and the other end to one of the iBooks firewire 800 ports. (the iBook has both the 6 pin a48d559.gif and the 9 pin. 24a3000.gif800 ports) To start up as the target disk you press and hold T immediately after pressing the power on button. once you see the firewire symbol bounce around the screen you can let go. Now its like connecting to a external hard drive.
Jun 18, 2009 | Apple eMac Desktop
My emac doesn't power on
unplug it over night and try to power up in the morning
Nov 17, 2008 | Apple eMac G4 Desktop
EMac screen resolution size is only one choice 800x600
1st start it in safe mode.install video driver from motherboard support cd.then start it in normal mode.then you may change your monitor resolution.
Feb 08, 2008 | Apple eMac G4 M9425LL/A Desktop
Apple MacBook Mac Notebook Logo
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
