Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
I'm not sure if it's suction or not, but it doesn't really pick up anything anymore.
  • 694 Answers
Check the following areas for clogs:
1. Hose. Detach hose at both ends and try to roll a marble through it. If clogged, you can try reversing the hose to **** from the "wrong" way. This may be enough to clear it. If not, you may need to take it to a dealer for clearing.
2. In port where hose attaches to tank. This is easy to clean, just pull out plug or remove dust holder and remove clog that way.
3. Short hose in power head. This may take a little time, but you should be able to clear it.
For 1 and 2, do not use sharp or pointy objects to try to clear.
This may result in tears and holes in the hose, resulting in a
need to replace it.
The hose may also have leaks in it, which means replacing it.
Posted on Aug 24, 2010
My irobot will run but doesn't pick up anything
Check your suction. If there is no or little suction at the hose end then check for a plugged hose and all the suction areas. Make sure your filters are clean as well. Should be one and possibly two.
Dec 02, 2016 | iRobot Vacuums
Royal carpet extractor not picking up water well
Try to follow the suction from the machine through the dirty water tank to the front floor suction piece. Make sure the dirty water tank is seated properly. Make sure there are no suction leaks any where.
Mar 21, 2014 | Royal Procision 7910 Carpet Extractor
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
I have a hoover steam vac F5915-900 I bought at walmart about 4 months ago. I used it about 5 times in differnet rooms. Today when I went to use it It won;t pick up the dirty water. I cleaned the filter...
Make sure the suction area of the face plate is clear of all debris. If anything else, call the number on the machine, it's still under warrantee if the machine doesn't work from normal use.
Sep 05, 2011 | Hoover Vacuums
Does not have any suction to pick up
Clean out the filter in the top of the cyclone chamber
Make sure there are no blockages in the tubes or hoses by checking for vacuum
May 08, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Suction hose
i would first double check the hose, remove it and drop a marble through it to be sure. make sure the bag is new and also check the filter underneath the bag if it is clogged it could cut the suction.
Sep 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
No suction when carpet cleaning. Also won't stand upright
Its possible that it may be blocked in the foot of the vaccum. try going through your instruction manual to locate details on how to disassemble the suction brush and connecting ducts. If you dont have one then use this link to download it. http://ubermanuals.com/node/1870
Let me know how you got on
Cheers
Jun 10, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
U5397-900 - wont clean carpet
could be, but probably just needs a new belt - they stretch.
Dec 16, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
24 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
