When firing the lochinvar knight boiler it went to "man reset high limit" on computer and says LOCK OUT !?!? is it air locked? the pump in on the supply side instead of the return side. does that make a difference?! please help asap! thank you
This kind of Manual High Limit issue can most likely be caused by two things :
1) If it's a Knight XL (399MBH and up), it's equiped with a manual high limit with is located in front of the boiler, behind the front panel just under the display bezzel. It has to be adjusted and reset (with the manual reset button on the control display).
2) If your unit is NOT equipped with that kind of Manuel High Limit, this message means that there was a low voltage wire that was shorted to the ground. Either the flow switch or the thermostat wire. The 24v fuse located on the main control board burned to protect the components. Lucky, Lochinvar provide replacements in the small plastic bag attached to the connection board.
Hope this help. Even if i'm late.
Posted on Nov 11, 2010
  • willer resende
    willer resende Nov 12, 2015
    thank you guys.that was exactly what was happening with my boiler. a u$3,00 fuse solved the problem
  • 8,220 Answers
Lockout is usually non confirmation of ignition. The control goes through a routine to verify flame. When none is detected the control locks out the ignition sequence and usually declares it only after a number of try's. 99% of the time the flame sensor is contaminated to the point it cannot sense the heat fast enough for the control. This video is of a high efficiency furnace with a lockout problem:
Posted on Aug 24, 2010
  • Dan Webster
    Dan Webster Aug 24, 2010
    If the flame sensor is ok then the next thing to look for is safety rollout switch that has popped. Rollout happens when something blocks the ignition from properly lighting. Rusty burners allowing too much flame or partially blocked smokestacks. Rollout switches are mounted all around the burner area. Their is no set number of them. One may be in the stack, 2 near the flame itself. 1 under the furnace.
  • QcTech Nov 11, 2010
    Sir, these units are scealed combustion. They have no rollout switches at all. And a manuel reset high limit is due to a water temperature, not a flame sensor or flame issue!!
My boiler displays a message lock out no flame ign.
What you are experiencing could probably be a malfunction with the computer part of the boiler. However, last January I had a similar situation. I kept on resetting the system and a message would come on. It warned me that there was no flame and I ended up calling a mechanical contractor to solve the issue. The cause of it ended up being that I hadn't been keeping everything well maintained and the system hadn't been able to properly read everything. It was explained to me that that was a good thing to get fixed as it could have led to potentially more hazardous issues. Have you been keeping your system clean and well maintained before this issue came about? Mechanical Contractors for Albertas Heating Systems
Dec 06, 2015 | Lochinvar Knight KBN286 226000 BTU High...
Vaillant boiler ECO Max 824E F 20 error
Did you bleed the air from the pump ? Sounds like a air lock
Jul 14, 2017 | Water Heaters
Mini max plus 150 fails to fire
It appears that the boiler is going into hard lock out. This is caused by successive ignition failures for some reason. After 3 attempts to light, a high limit trip, low water flow, etc, the unit will lock out and will require a power reset in order to reset the ignition control. You should have the cause investigated to ensure safe operation.
Aug 10, 2009 | Pool & Spa
Non i;n working boiler
Did you put automatic vent plugs on this boiler?This help stop from having air locks.I would try bleeding the high pipe to see if any air come out.The other thing I would check is the valve that out for the pump to pump water around.
Mar 17, 2009 | Water Heaters
Burnham ledv boiler, honeywell primary control will lockout after 1 or 2 cycles. reset, get the same results. works fine during the summer
I'm sorry to hear! On mine, another model of Burnham , there's a grey box (approx 4" high by 5" wide) on the front of the boiler. This cover slides off and the control settings are underneath. My manual says low limit must be 20 degrees below high limit else they will lock out each other. I find this to be the case when a maintenance man's "tuned" the settings. My manual also says to set the differential knob to 25 degrees. There are some manuals on the burnham.com site along with their phone number.
Nov 11, 2008 | Heating & Cooling
Heating & Cooling Logo
1,616 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
