Question about Dishwashers
Frigidare dishwasher model # NDB 631 RF 53. Washer runs but does not dissolve soap and jet tablet. Does that product not work with this dish washer?
  • Dishwashers Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Aug 24, 2010
Why is my defy DDW172 not drying the dishes at the end of a programme and why does it sometimes not release the tablet from the holder, messing up the inside of the dishwasher
Try using jet dry, raising the temperature of the water. If that doesn't work there's a possibility the heater isn't coming on. The soap dispenser is best used with powder. The tablets seem to work best by putting them in the bottom of the dishwasher where they can dissolve.
Jan 21, 2015 | Dishwashers
My dish washer soap does not dissolve, whether or not I put the tablet or the pillow into the soap dispenser. Is it the soap dispenser door? Would hard water buildup create low water pressure so the soap...
The most likely causes are the you are using a tablet in a gel coating but putting the tablets into the dispenser drawer when the dispencer drawer is damp, thus causing the tablet to stick inside the housing; or, if the dispenser drawer is releasing the tablet into the bottom of the cabinet then I would say you have a problem with your water heater. In which case you would need an enginner to come and replace the heater.
Hope this is of help
Jan 25, 2011 | Maytag MDB7100AWB Dishwasher
The soap holder is opening during the wash cycle but the soap tablet is not dissolving. Any ideas?
Is the water coming on? Is water hot enough? Is washer overloaded, water jets aren't hitting the soap? Maybe try a different brand of soap tablet? Run the dishwasher in "heavy soil" mode which will use hotter water and run for longer?
Nov 20, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Help! My dishwasher doesn't rinse soap off my dishes anymore
try a few applications of jet dry DISHWASHER cleaner to remove excessive build up of calcium/hard water deposits...sounds like the water temperature is too low upon the initial fill cycle to assist in dissolving the soap.the water temp. must 125 degrees to insure soap activation/ and dissolve it.check for obstructed spray arm as well
Mar 06, 2010 | Frigidaire 24 in. PLD2850 Built-in...
My dishwasher is fairly new, about a little over a year old. Recently, in the past two weeks when I run it, the dishwashing tablet does not dissolve all the way and my dishes are left with soap residue all...
Check your settings. Set it to the longest and hottest cycle you have and do a load. Also, be sure to always run the hot water into the sink and let it get as hot as possible before starting the dishwasher. Otherwise you could be filling the dishwasher with cold water and it will not be hot enough to dissolve your tablet.
Oct 02, 2009 | Dishwashers
My Hotpoint Aquarius diswasher won't dissolve the washing tablets
I don't have a solution, but the exact same problem is happening with my dishwasher. Nothing is getting cleaned properly.
Did you manage to get the problem fixed?
Jun 01, 2009 | Dishwashers
Water does not make it to the jets
You need to take a flexible wire and stick it in each of the jet holes, all of them. Then run the machine, so the water can dissolve the soap. repeat the process w/o dishes/ soap (lather rinse...repeat)
The Best!
May 19, 2009 | Bosch Dishwashers
Soap is in the dispenser after dishwasher has been run
You need to clean your particle screen under the heating element. It is found at the bottom center of the washer under the heating coil. It is usually a plastic mesh screen and sometimes are removable. This needs to be cleaned really good about every 2 months. This will stop the problem with the suds. Good Luck This Should Help!
By the way I see that you soap won't dissolve this is not because of water temperature it is that the jets in the washer arm are clogged. You need to clean these one by one with a small cleaning device and brush. When these clog the jets of water don't come out with any force they just trickle. Clean the jets(on the arm that spins at the top and bottom of the washer and your screen and it will be like having a brand new washer.
Nov 23, 2008 | Maytag 24 in. DWU9202 Built-in Dishwasher
Soap does not seem to dissolve or clean
Probably a sticky dispenser door. Run for a few times with the dispenser open and put a tablet in the cultery basket
Nov 23, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
