Question about Maytag Kitchen Ranges
Will not heat up to right temp. - Maytag Kitchen Ranges
  • Maytag Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on Aug 24, 2010
How to reset Kenmore Elite 665-16572202 Dishwasher...clean light blinks 7 times pauses then repeats. My model does not have a Heated Dry button it has an Air Dry button.
Here's the key sequence(s) to use, depending on how your keys are labeled:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
This will start the diagnostic cycle. Let the dishwasher run for a few minutes, and then press Cancel to stop the dioagnostic cycle and clear the error. Please note, that this clears the error, but if you haven't found the cause (water-not-heating error), the condition will come right back the next time you run the dishwasher.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jan 19, 2015 | Kenmore Dishwashers
What is the sequence to reset kenmore dishwasher 665.16719000? The buttons from left to right are pots/pans, normal wash, water miser, china gentle, quick rinse, high temp, air dry, delay wash, start
Press "high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash"
All the lights will go solid at which point you press cancel to reset the board.
**NOTE** if you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
Apr 03, 2014 | Kenmore 24 in. 16052 Built-in Dishwasher
My 2001 buick lesabre does not blow heat. a/c works great. when switch to heat, it gives a quick burst of heat and then cool air. engine coolant temp is normal right around 200*F. Any suggestions?
under hood feel the heater hose temp they need to be the same temp very hot. if ok
check for the blend or mix door not opening
you can remove the actuator motor and move trap manually to see if stuck
Oct 24, 2013 | Cars & Trucks
Ge gas oven jgbp28dej3ct.. oven pre heats good to right temp but wont maintain temp during cooking.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 29, 2011 | GE 30 In Freestanding Gas Range ...
Over will not heat up beyond 175F, according to temp display enven when high temp selected. When Self cleaning selected oven does not heat up ,
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
heatman101
Jan 07, 2011 | Maytag MER5875QAS Electric Kitchen Range
I have a new bryant 2.5 ton 410 puron heat pump and it shut off when the temp get cooler. The temp right now is around 36. Is there anyway to get it to shutoff at a lower temp. so the aux heat won't kick...
Heat pumps only work down to a certain temperature, 35-40 degrees outside temp. Once it gets that cold the system cant pull any heat from the outside air and the aux heat kicks in to make up the differance.
Nov 23, 2010 | Heating & Cooling
TB8220U Commercial Thermostat keeps running when temp is right
the temp coming out of the vent should be 20 to 25 deg more then room temp and if AUX heat kicks in the temp should be even more.
Jan 08, 2009 | Honeywell Electronic Programmable...
Kitchen Ranges Logo
48 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
