Question about John Deere 4020 Gas & Diesel Tractor Radiator
4020 john deere compact diesel. Lost hydraulics and do not know how to check fluid level. Worked good and just quit. Can not see any leaks??
  • 43,501 Answers
I doubt that it is the fluid level...it's been a few years... but I seem to remember there being a couple at the front of the motor that ran the hydralic pump...I am wondering if your problem is not there...tthe hydralic pump sits under the fuel tank at the front of the tractor... check there to see if everything is working right there...of course it could be the pump its self that has gone bad...
heatman101
Posted on Aug 24, 2010
My john deere 4200 hst tractor quit moving,power steering quit,frt loader quit all at once fluid level is ok
hydraulic pump problem
check drive connection to the pump
check input line to the pump has no air leaks and sucking air
Oct 25, 2016 | John Deere Garden
I have a John Deere 870, and the PTO quit working, first of all, the pto quit letting the mower deck go down then it quit working?
check your fluid level for the hydraulics and look and check that the pto rods are connected and adjusted correctly
Jul 31, 2016 | John Deere Garden
Replace a fanbelt on john deere 4020 diesel tractor
Most older models had the adjustment on the alternator. loosen it and push it toward the engine. remove & replace the belt. Pull the alternator away from the engine until the pulley cannot be turned by hand due to the tension. Tighten the adjustment bolt to secure it. Don't overtighten the belt.
Sep 22, 2014 | John Deere 4020 Gas & Diesel Tractor...
John Deere 310G that the hydraulics quit working
You just go to the link I attached I'm sure you will get the solution of your problem.
John Deere 310G
May 29, 2017 | John Deere Garden
The hydraulic steel line on my 2010C bucket loader broke and I dumped a good amount of fluid before shutting everything off. Replaced line and filled tank up, everything worked fine for about 1/2 hour,...
Like other hydraulic systems, there is probably a procedure for bleeding the lines after loss of most of the fluid. You may still have air trapped in the system and once it works its way to the cylinder, the cylinder is working with air instead of fluid and the air compresses instead of doing work.
Sep 16, 2010 | John Deere 420,1020,2010,2020,2510,2520...
JD 4020 Row Crop Tractor; No power Steering, No
In regard to the problem - JD 4020 Row Crop Tractor; No power Steering
What was the problem and how did you fix it I'm having a simlar problem
Apr 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John deere 84 410B turbo, wont drive up an incline
Try changeing the hydrolic and transmission filters,also recheck the fluid level.Check the fluid level with all cylinders retracted and if it is overfull then drain it to the top of the full line.
Dec 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 4020 Gas & Diesel Tractor Radiator Logo
435 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
