Question about Acclaim Alias for Windows
Have a alisun sunvision c14, the timer is set to 15 min how do i increase the time as the tubes detoriate
Sound goes off after 15 Min
Assuming it is not hardware but soft settings...
1) Check and make sure that your TV does not have the timer set.
The Timer feature allows you to set a day and time for the TV to turn on automatically and the device and channel to display when it switches on. If the TV is already on at the requested time, the TV automatically tunes to the channel you designated in the Timer menu.
When the Timer turns on the TV, the following message is displayed: "Press a button for the TV to stay on." Press any button on the remote control within five minutes if you wish the TV to remain on.
Note: The TV clock must be set before you can use the
Timer feature (see preceding page to set the clock).
On/Off
Press down arrow / up arrow to enable or disable the Timer.
2) If not working, try SYSTEM RESET. Press SYSTEM RESET button on the front panel with pointed object (e.g. straight paperclip). TV turns off, green LED flashes for about 1 minute. When it stops flashing turn the TV on again. All settings other than Parental Lock need to be set again using the manual.
3) TV RESET. If all else fails for soft error. Your manual describes this last resort for soft type error. It could be hardware problem needing more expertise.
Manual can be viewed on a computer at
http://www.audiolabga.com/pdf/V32-V32L_Service_Manual.pdf
Aug 05, 2014 | Mitsubishi WD-62531 Projection Television
How do i set the clock on a taylor 5846 digital timer
Press the Mode button until you are on the clock.
Then press and hold the Start/Stop button for 3 seconds.
There should be a beep and the digits will begin to flash.
Press the Min button to increase the Hours and press the Sec button to increase the minutes.
When you have the time set, press the Start/Stop button to finalize the setting.
Nov 18, 2013 | Hardware & Accessories
How do I reset the clock on a Taylor 5846-9 kitchen timer?
Nov 03, 2013 | Taylor Hardware & Accessories
How to set the clock on a taylor 5846 Slim Digital Timer
Feb 13, 2013 | Hardware & Accessories
Alisun 24 bulb 26 SXB wiring diagram
Why do you need a diagram? Tell me what the bed is doing or not doing. I may be able to help.
Jul 28, 2012 | Wolff Sunvision Pro 24S Tanning Bed
I am looking for a users manual for a alison sunvision v180 xxl sunbed to see how it is wired to the electrics
call 0808 108 7778 for all alisun sunbeds parts and trim, i have a 180xxl in my tanning salon
Jan 05, 2011 | Kitchen Ranges
Can I set my timer to run for 15 minutes when I push the start button and then shut off
There is no reason why not, usually one can increment a timer in one min intervals, so simply set your timer for 15 "Intervals", or 15 Mins, and you should be OK.
Aug 31, 2010 | Woods Hardware & Accessories
We have a timer on our tankless hot water heater-how do I set it to reflect the current time? It is a large dial with tiny pins to pull/push backward. I understand the on off function of the pins but need...
very simple you push the middle and turn to set it to the timing you want current timing. the best times to set a recirculating pump in a water heater is 20 to 30 min before you take a shower in the mornings 15 min is adeal and dont leave the timer on for more than 15 min which represents each pin. Remember you are trying to recirculate the cold water out off the lines and replace it with new water so next time you open your faucet you get instant hot water. ones hot water is in the line you do not need the pump. i also recomend to set the pump 15 min before you get home or before you take a shower int he afternoons there is really no pint to leave the pump all day or for longer than that because the objective is to replace cold with hot water you can even set it to turn on and off every hour for 15 min at a time if someone is home all day but remember usually the recirculating pump is there for the faucets that are far away from the water heater so if you do not used them all day and only in the morning and at night before going to bed then there is really no point to leave the pump on and waste more electricity.
Sep 28, 2009 | Noritz 7-9.4 Adjustable Tankless Wtr...
LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
Jun 08, 2008 | Dryers
Acclaim Alias for Windows Logo
118 people viewed this question
Top Acclaim Video Game Consoles & Games Experts
Colin Stickland
Colin Stickland
James Wishart
Josh Hannegan
Josh Hannegan
Level 1 Expert
Are you an Acclaim Video Game Console and Game Expert? Answer questions, earn points and help others
