Question about EliteGroup P4M900T-M (V1.0) Motherboard
4gb ddr2 ram installed but only showing 2.5gb using windows 7 64bit ultimate
  • 75 Answers
Do you have a video card? If you using integrated video. the integrated video use the 1.5gb memory of your ram. to check how much your video adapter use.. Goto windosws start -> setting -> control panel -> Display -> Setting -> Advance -> Adapters, you will see the memory size.
Posted on Aug 24, 2010
2*2GB (4GB) ddr2 shows up as 2*1GB ddr2 (2GB)
It could be a problem if you are running a 32 bit operating system. I know that there is a limit of around 2gb on any 32bit windows install. this can be fixed by installing a 64bit version, IF your hardware supports it. You would need a 64bit cpu to install 64bit windows. If this is not the reason you are having the problem, the only other reason that would make sense would be that your motherboard doesnt support more than 1gb of ram per DIMM hence it shows that two are insalled but can only use one gb each. This i think is the more logical answer because I think the limit on GB for win 32bit was more like 3gb. good luck
Oct 08, 2012 | Intel DG43NB Motherboard
My motherboard model: GIGABYTE GA-M68SM-S2L, has no output appear on my LCD. I use external videocard and i change my 2 memory but still not working.what I supposed to do. Please help me guys.. Thank you
Hi, you can download a manual and drivers here:
http://www.gigabyte.com/products/product-page.aspx?pid=2670&dl=1#dl
You have to be sure you have used the right type of ram
and it have to be inserted correctly.
  1. 2 DDR2 DIMM memory slots (supports up to 8GB memory)(Note 1)
  2. Supports dual channel DDR2 800/667/533/400 DIMMs
  3. Supports 1.8V DDR2 DIMMs
(Note 1) Due to the limitation of Windows 32-bit operating system, when more than 4GB of physical memory is installed, the actual memory available for the operating system will be less than 4GB; Windows 64-bit operating system doesn't have such limitation.
You can try to use the onboard graphic
and see if that works.
Check also the bios settings.
The external graphic could be burned off or you could have
pushed it when you installed the ram memory.
Try to remove the card and insert again carefully.
If you are useing the wrong type of ram the mainboard will not boot.
Sep 15, 2011 | Intel Motherboard
I m trying to upgrade my HP compaq nc6320 RAM MEMORY from 1GB to 4GB, Do i need BIOS upgrade if yes from were i can find the drivers and how can i do it? thanx i am gone wait for respond......
As far as I know, the machine supports 4GB of ram, so you purchase the ram modules from a pc parts dealer and install them inside the machine, removing the existing ram, there are 2 slots, so you need 2, 2GB cards.
You do not require any drivers or bios update.
Windows will need to be upgraded to 64Bit version if you wish to use the full capacity. as normal windows is limited to 3-3.75GB
Further questions? let me know.
Sep 01, 2011 | HP Compaq nc6320 Notebook
Can my mercury motherboard PI945GCM.V1.0 support 4(2+2) gb ddr2 ram
This motherboard will support only Maximum 2GB DDR2 RAMS.
Thanks for using FixYa.
Jun 06, 2011 | Mercury P4VM800M7 Motherboard
Hi i want to know if my laptop is with ddr 2or ddr 3,it is 1gb presaroi cq 60
The details about your laptop's ram,
Maximum = 4Gb
Technology= DDR2 SDRAM
Form Factor =SO DIMM 200-Pin
So, ram installed on your laptop is DDR2. If you need/want to upgrade, you have to look for and buy DDR2 type ram.
Good luck.
Aug 15, 2010 | Compaq Presario CQ60-220US PC Laptop
I have a new computer..PA74M5 AMD 740G support AMD AM2 + Athelon64 into 2 processor. 4GB DDR2 RAM ... 500 GB harddisk. i need sound drivers for it... real tech 2.75 version.. please help.. i am using...
download the latest sound driver from Microsoft.com Compatible with Window 7
go to
http://www.download3k.com/Install-Realtek-High-Definition-Audio-Vista-Driver.html    and click on download link . then follow the installation process ok.
Rate this solution........
May 05, 2010 | Computers & Internet
Problem with upgrading my acer extensa 5620z memory to 4GB
Hi there.
I recommend you get another stick of SODIMM to replace what seems to be the faulty stick.
If you are using XP or Vista X86 (32bit) then the system will only recognize 2.8 - 3GB of memory, only 64bit operating systems recognize the full 4GB.
Good luck ad thanks for using FixYa!!
May 24, 2009 | Acer Extensa 5620 Notebook PC
How much Ram am I using?
Unless you are running a 64-bit version of XP or Vista, Windows will not report the full 4GB. It's because of the way the program addresses and uses RAM. Here is a page that gives a little explanation. The bottom line is that if you want to get the full use of 4GB of RAM you need the 64-bit operating system.
Apr 18, 2009 | Dell Dimension 5150 Intel Pentium 4 w/HT...
I put 2gb of DD2 ram in 800 mhz it wont show a screen? To fast of
Eee PC models use 533/667 MHz DDR2 RAM via a standard SO-DIMM module.
The hardware supports up to 4GB (2GB for the 1000 series, and some of the 900 series).
Feb 25, 2009 | ASUS Eee 900 Notebook
Windows won't see all of my 4GB of RAM but BIOS does! Why?
Windows xp will usually only see 3.5 gbs of ram even in your motherboard can support more. WIndowns vista does recognize more RAM or i also believe windows xp 64bit recognizes more ram. Nothing wrong with ram or your computer its just your operating system.
Dec 18, 2008 | Dell PowerEdge 1600SC Server
EliteGroup P4M900T-M (V1.0) Motherboard Logo
347 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
