Question about Canon PIXMA iP90 InkJet Printer
The unit is printing fine but the unit is making a high pitched squeal right before the paper is almost out of the unit and then it stops after the paper is out and it goes through a process similar to when the unit is first turned on. Any suggestions? Unit is the Canon iP90.
  • 46 Answers
It needs to be oiled then
Posted on Aug 24, 2010
My Hp 1200 laser printer makes a high pitched squealing noise and I have to pull the plug out to stop it.
The fuser is the part of the printer that heats the toner to the paper. turn the printer around and open the back cover. You should see a long black bar with green clips on either side to release a paper jam. There may also be rollers in there. Make sure there is no debris in the fuser, and that those clips are in the functioning position (usually down). If the fuser is removable, which I don't think it is in this model, take it out and then reinstall it. Then give it a shot. Usually though high pitched squeal is a toner cartridge thing. If you are using reman cartridges try a new (actual hp) cartridge from office depot or staples.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
May 13, 2014 | HP LaserJet 1200 Printer
Canon imageclass MF8180c squeals
Try replacing the Drum Unit, this is a problem I have encountered many times as a service technician. most recently I had one that was at 89% remaining and every time the unit begins the print process it makes a high pitched squeal.
May 01, 2012 | Canon imageCLASS MF8180C All-In-One Laser...
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
Laser jet 1600 printer high pitched squeal
It proberly has dust in the printer near the spool (the picture below)
Sep 11, 2009 | HP Hewlett Packard LaserJet 1600 Printer
High pitched squeal on new brakes
Break squeal can be stopped by applying shims or anti-squeal compound to the pads.
Apr 05, 2009 | 2005 Ford Freestar
RCA HD52W59 makes a high pitch internal squeal sound
coil LL0037 resolder then with a glue gun glue top of coil and down.OR replace coil.
Feb 17, 2009 | RCA HD52W59 HDTV Projection Television
High pitched squeal
Hi...
Does the squeal come from the TV cabinet or the speaker?
If from the cabinet , it's most likely the Horizontal high-voltage section of the set.
Find someone that's good with hand tools,unplug the set from the wall outlet, let it sit for a good 30 minutes.
have someone open up the back of the set and dust out and vacuum out any dust from inside the set.
Put back together and try it out.
Jan 01, 2009 | Samsung TXN2034F 20" TV
Papaer will not feed
High ITConsult And MarkoP
The high pitched whine and the paper stopping just before the fuser (the hot) unit is a known issue on the C3000 and C4100. If you are still searching for the solution to this issue, let me know, as I now have a working fix for the problem.
Reply to this post for further info.
Jul 10, 2008 | Epson AcuLaser C3000 Printer
Canon PIXMA iP90 InkJet Printer Logo
97 people viewed this question
old marine
old marine
