A/C been running all dayand now the line are not sweating and not cooling
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Aug 24, 2010
Mr slim MXZ, working but not cooling, no error codes on outdoor unit
Possibly the outdoor board??? Are the copper lines sweating? Are you heating or cooling?
Jul 15, 2017 | Heating & Cooling
R-22 home condenser unit low side and high side pressures when running
Pressures look good but to know if it is charged correctly you have to do a sub cool or superheat to know for sure. Rule of thumb is if turn unit it on let it run 10 minutes. If the suction line sweats and is cold. Might be proper charge.
Jun 24, 2014 | Ruud Central System Air Conditioner
Unit not cooling inside below 72 degrees lines sweating
how hot is it outside??? 20 degree split is usually the norm ,,,,,outside 95 then inside will be 75,,,,,where is the line sweating ,,, it should sweat near outdoor unit
Jun 02, 2014 | Ruud Central System Air Conditioner
Freezer not cooling not ice forming in the ice tray down compartment not cooling compressor working continiously what is the refrigarant use in this fridge and I feel filter dries blocked or not efficient...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 06, 2010 | Refrigerators
I have a Ruud 2 ton split system and the system will not cool. The compressor and fan on the outside unit works and the fan blower on the air handler works too. The temp on the lines coming into the...
The small line coming in from the outside unit should be warm to hot and the larger line should be cool and sweating with water forming on it. I am taking for granted that the unit was working if so it sounds as if the unit is low on freon. your inside coil should be sweating a lot from top to bottom if it is only cool or sweating on the bottom but less to nothing up top you are low on freon. When very low the unit will stop working just like a broken valve in the compressor. If it is just a little low it will not cool properly and at night it might even freeze the inside coil up.
Aug 08, 2010 | Ruud Handle Air Conditioner
Keeprite 2300 sx a/c w/ 2 speed fan never seems to go high speed .should I be able to hear it change and how do I dainose the problem ? and does this cause poor cooling ? the compressor unit line is cold...
I need more info. I can't seem to find your indoor unit. Is this a 2 stage cooling unit or just 2 speed fan? Please send the model number of your indoor unit.
Apr 11, 2017 | Heating & Cooling
Unit not cooling well both suction and discharge lines cool dischrcharge line [ small line] sweating
the "Discharge" line sweating on a mimn split is normal all of the flow metering is done in the outside unit . as to it not cooling well are the filters clean? if they are you more than likely have a leak and need to get is serviced
Jun 12, 2010 | Fujitsu 18C1 Air Conditioner
99 rodeo ran out of gas now no start
If you can hear the pump run and you get no fuel its the pump, If it blew the fuse i would say the pump tied up. That happens when you run around on empty a lot, gas is what keeps pumps cool when you run under 1/8 of a tank pump is not submerged in gas to keep cool hense pump burns up.
Mar 09, 2009 | 1999 Isuzu Rodeo
Heat Pump
Your inside cooling coil in the air conditioning mode could be frozen over. Change the fan setting to on and operate it that way when in the cooling mode. Turn the air conditioning OFF with the fan ON to clear the coil of frost which should take about 1 hour.
The fact that you have sweat on the large line means that the temperature of the gas inside the line is below the due point of the moisture in the air. A good tech would measure the pressures and temperature of the system to get what is called superheat to determine proper system charge of refrigerant.
Jun 14, 2008 | Heating & Cooling
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
