Question about AT&T LG CU515 Cell Phone - Black
Contacts on my handset aren't showing up, only contacts in the smart chip show up when i press the "down" button for my address book
    Problem Solver:
  • 10 Answers
Goto the "Address Book", Then goto the "Settings" And there should be somthing on being able to change which Numbers and names to list, You can choose the SIM Card, or the Phone Memory. Most, if not all modern phones have this option.
Posted on Aug 24, 2010
Just got my Pantech Ease today, it won't let me add to my Address Book, it is not full...I only have 24 contacts...help?!?
Try this. First make sure your phone mode is not in Easy Mode but is set to Advanced Mode. Next press either Contacts or Address Book (depending on which screen you are start from). Either of these will take you to the Address Book screen. Now press the upper left icon which has a picture of a man with a wrench. This will take you to the My Settings screen. Scroll down to "View Contacts from" and press on it. Now try looking in both "Phone" and in "SIM". See if you find your contacts in either of those. It doesn't matter which one they are in because if you select "Phone and SIM" your contacts will then show up in your address book.
You can also use "SIM Management" and/or "Save Contact to" for managing exactly where you decide you want your contacts to reside. It is kind of confusing and they certainly do give you a lot of options and flexibility in managing your contacts. Probably more than most of use ever need but still nice to have if and when needed. Sounds like you might need it now; at least I hope this is the solution to your problem and you don't have a more serious problem. I hope this is helpful.
Jan 22, 2012 | Pantech Ease P2020 AT&T
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
Transfer Palm to IPhone
Bring up Palm Desktop. Make sure your Palm phone is synced up. Show the Address page, select all contacts (Ctrl-A), and export them with File, Export vCard. This puts all contact information into a single file as a sequence of vCards.
Bring up Windows Address Book. You can find this in Start, All Program, Accessories, Address Book.
Using Windows Explorer, drag the vCard file you created in step 1 to the Windows Address Book window. I had never used Windows Address Book, so it was empty. If yours isn't empty, you'll have to decide whether you want to merge your contacts.
When you drop the file, you'll get a window asking you to confirm the first contact. Press OK. Another window will come up for the second contact. Press OK until all windows are gone. It's easiest to hold down the Enter key.
Bring up iTunes with your iPhone plugged in. Go to your iPhone page, to the Info tab, and configure it to sync from Windows Address Book. Click Apply in the lower-right corner of the window.
Sync your iPhone. Verify that your contacts transferred over.
Tell iTunes to stop syncing with Windows Address Book, since you probably only wanted a one-way sync. Your contacts will be backed up anyway by iTunes, so the Address Book sync feature doesn't buy you much.
Oct 29, 2009 | Apple iPhone Smartphone
When i pull up my address book, it show "Business" contacts...I am unable to change it to "Personal" address book. Any suggestions?
To change it to personal contacts follow the bellow mentioned steps:
1) Select adress book
2) Press menu
3) Select filter
4) Check on personal
5) and you can enter ur contacts under personal contacts.
Jun 22, 2009 | RIM BlackBerry Pearl Smartphone
Hy is my blackberry pearl not showing who my message is from
Cause:
  • Number is not saved in the address book
  • Issue with the setting in the handset
  • Software issue
Resolution:
  • If the name is not saved then saved the name in the handset
  • In the handset go to Call logs -> Menu -> Option -> Smart Dialing -> Country Code is +91 and Option ->Security Option -> General Settings -> Include Address Book -> Yes
  • If the above two option is done then re-install the software.
Jun 18, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Contacts
Your SIM Card is like a floppy disk, so if you want to permanently add those people from your sim card to your Blackberry - you need to copy from the SIM into the BB Address Book. Otherwise they will be on the SIM Address Book, and you can always go look them up - but they are not saved on the BB itself.
BB: To access your cell phone address book:
  1. Scroll to select the ADDRESS BOOK icon and press [Trackwheel] to select.
  2. Press [Trackwheel] again to access the Menu screen for the address book.
  3. Scroll to select the SIM PHONE BOOK and press [Trackwheel] to select.
  4. system should say LOADING SIM PHONE BOOK.
  5. Then if you select the menu - you should have an option to COPY ALL TO ADDRESS BOOK, select YES so it will copy whats on the SIM to the BB Memory..
This will start the download process to read the contacts stored on your SIM card which were copied from your cell phone.
Mar 08, 2009 | RIM BlackBerry Bold 9000 Smartphone
Address book won't show contacts
Go into your Address book
Hit the Menu Button
Go to Filter
Make sure that both the business and personal box's are NOT checked
If they are checked you need to uncheck them
This should restore your contacts... If it does not restore them then you have a Bigger Issue!!!
Feb 15, 2009 | RIM BlackBerry Curve 8310 Smartphone
My inside screen will not show anything. i can receive and send calls bu dont know who im calling. ive never dropped it, gotten it wet, or damaged it in any way .help
To save contacts on a z310a that has a broken screen, do the following: 1.From standby, (make sure the backlight is lit up) press the center button once 2. Press down once to go to address book 3. Press center button to enter address book 4. Press RIGHT select button (upper right button with line through it) to select options. 5. Press down FIVE (5) times to go to Advanced 6. Press center button to go into Advanced 7. Press down FIVE (5) times to go to Copy To SmartChip 8. Press LEFT select button to enter 9. Press LEFT select button to select "Copy All" 10. Press LEFT select button to confirm. Wait a couple of minutes to make sure all your contacts were transferred.
Jan 08, 2009 | Sony Z310a Cellular Phone
Unable to view my Address book
This is typically caused by a filter being applied in the address book. Open you address book, press the BB menu button, and select filter. Once you are in the filter options, make sure that all check boxes are unchecked, then exit back out.
This may not be the cause of everyone's issue, but it may be a solution to some of the problems.
Another thing to check is if the contact are actually in the "Sim Phone Book" opposed to the regular address book. Open your address book, press the BB menu key, and select "Sim Phone Book". After doing this, you may see all of your contact in there and you should be able to copy the contacts to the BB.
Aug 18, 2008 | RIM BlackBerry Curve 8310 Smartphone
Address book
That's easy just goto your address book
2.press the menu button
3.select filter
4.press the menu button again
5.and select uncheck filter'
thats should make your contacts reapear
Jan 22, 2008 | RIM BlackBerry Pearl 8100
AT&T LG CU515 Cell Phone - Black Logo
48 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
