Question about Hotpoint Refrigerators
My Hotpoint refrigerator (model HSM25GFTA SA) leaks out of the back, right corner when we push the water dispenser in front. It may be important that a couple days someone pushed the temperature setting for the freezer up to "9" for an unknown period of time. The freezer has been set to "5" for the last two days. Oddly the icemaker works normally. Yesterday I replaced the water filter. Is the water-supply line frozen, or is there a worse problem? TIA
catriver
  • 878 Answers
SOURCE: water leaking onto floor
Angels, sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a baster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear. Catriver..post back.
Posted on Dec 22, 2006
  • 159 Answers
SOURCE: Problem with water flow in LG LRBC22544 Bottom Freezer Refrigerator
Sounds like you have excess pressure building up in the water system. Is the water dispensor working? If not it sounds like you have a frozen line somewhere or the valve in the door is not working to allow the water to dispence.
Posted on Jul 13, 2007
rylee_smith
  • 8619 Answers
SOURCE: Kitchenaid kscs25fjss01 (2002) front panel not working
Hi
If  The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Apr 02, 2009
jmgldsmth
  • 2005 Answers
SOURCE: Water Supply Line for Ice maker and Water dispenser is leaking.
Go to the hardware store and get a brass tube sleeve coupling; cut off the old tube end, slide the hex cap thread side out onto the tube, then; slide the tube sleeve onto the tube and, seat the tube into the supply valve then tighten the hex nut.
take the old parts to the hardware store to compare; the size is most likely 1/4" the part can be found in the "evaporative cooler parts" section of the hardware store
Posted on May 28, 2009
  • 62 Answers
SOURCE: Freezer and fridge are not cooling but we hear the sound of the refrigerator
your defrost heater or timer is not working . rotate you defrost timer until it clicks and check if its is defrosting if it is let it defrost for about 10 mins and turn the timer some more to take it out of defrost. replace timer
Posted on Jun 02, 2009
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Problem: Water continually drips from water dispenser spout
Should be the water valve in the back. Over time the seals break down our debre in water will cause to leak. Sometimes new water filters will also cause small issues but shouldn't last long.
Aug 18, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Water leak on floor under refrigerator
The line going into the dispenser is a 5/16 line. You'll have to remove the front of the dispenser on the door to get access to the line to unclip it. Once you have that done you can pull the line out from the bottom. At this point there are a variety of different unions, compression fittings, etc. to splice the line. After that you just feed the line back through the bottom of the door, clip it back in place, put the dispenser back together and your done.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 15, 2012 | GE Refrigerators
GE Hopoint Model #HSM25GFTA SA
my refrigeration no out water ....
Feb 09, 2012 | Hotpoint HSS25GFP Side by Side...
We have a HSM25GFTA refrigerator. The water is not coming out of the dispenser. I change the filter regularly so that is not the problem. Can you assist with some suggestions? Thank You
I had same problem. first locate your water shut off to the refrigerator. find this by following the clear plastic hose going into the back of refrigerator. shut water off and then unhook the water input hose. then put the hose in a bucket and have someone turn on the water. if no water comes out it is probably the shut off valve. but if water does come out then turn water off. if you have an ice maker and water on the front then there are two solenoids that operates each function. so you more than likely have a bad solenoid on the water input.
hope this helps
Jan 31, 2011 | Hotpoint Refrigerators
How do I replace the water dispenser tube for a Kenmore Coldspot model # 106.53769201. The end of the line disintegrated at the spot where you put your glass under the dispenser.
Ice makers and water dispensers are convenient to have on your refrigerator, but can also cause a lot of aggravation if they are not functioning properly.
If your water valves are not defective and you are still experiencing water or ice delays, you may have a clog in your refrigerator hose line.
Instructions and material needed to fix it up.
  • Towel,Flathead screwdriver,New water hose
  1. Turn off the water supply to the refrigerator and place a towel under the line to soak up any residual water that leaks from the hose when you remove it. Unplug the refrigerator.
  2. Disconnect the hose from the back of the refrigerator by pushing in on the collar while pulling the water tube out. If you have a model with an ice and water dispenser, you will need to disassemble the dispenser on the front of the freezer in order to completely remove the water hose.
  3. Remove the water drip tray from beneath the ice/water dispenser and locate the screws at the bottom of the cover (if any). Remove screws and pop off the panel that houses the dispenser. If the unit does not have screws, you will need to pry the cover off with a flat-nosed screwdriver.
  4. Once the cover is removed, you should be able to see the screws that hold the dispenser unit in place. Remove these screws and reposition the unit so you can free the water hose, by pulling it through the dispenser.
  5. Thread the new water line through the freezer door and reassemble dispenser unit. Push the new water hose into the fitting on the back panel, making sure it is properly seated. Turn on water supply and check for any leaks before moving the refrigerator unit back against the wall.
Good Luck and thanks for using fixya.
Jan 16, 2011 | Kenmore 57029 Side by Side Refrigerator
It's leaking
Mine was leaking from the front left freezer side. I removed the tray at the bottom and saw that there is a drain hole in the back. I removed the sheet of ice that was covering the drain hole and poured vinegar and hot water to unclog it. That was the problem all along! The drain hole was clogged causing the water to drip out of the front. Whew!
Jul 02, 2010 | Hotpoint HSS25GFP Side by Side...
Water is leakig from behind the control panel
You did the right thing by trying to clear the drain in the back of the freezer, but it must not have cleared. If the ice maker is not leaking then the only other source of water can be defrosting ice build up on the evaporator coils when it goes through its cycle. You know your drain is clear when water can flow down it. Defrosting your refrigerator completly usually solves this. If it does not, then check to make sure the freezer compartment fan is working, next it may be either your thermostat or timer control. Those are pretty much the only possibilties.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Aug 25, 2009 | Hotpoint HSS25GFP Side by Side...
Model number
usually it is located at either buttom corner. most likely the right buttom corner.
Feb 02, 2009 | Hotpoint FFU00 Side by Side Refrigerator
Refrigerators Logo
180 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
