Question about PfaFF Creative 7570
I'm trying to fix a Pfaff 7550. Motor doesn't start. Foot pedal is working. No power at the motor. Any answers to this problem?
5 Suggested Answers
  • 8 Answers
SOURCE: pfaff 7550
Press the small white number 1 button while turning on the machine. You language selections should appear.
Posted on May 20, 2008
SOURCE: PFAFF creative 7550 sewing machine
batteries went out and los all basic memory. machine cannot sew. cannot choose sticthes. How can I reprogram?
Posted on Jul 05, 2008
  • 323 Answers
SOURCE: Foot control for PFAFF won't work
These machines need to be seen by a technician who can disassemble the motors and replace the carbon brushes. You should have them serviced at the same time since it doesn't take that much longer to do everything.
sewman7
Posted on Sep 27, 2008
SOURCE: foot pedal does not function on pfaff 7550
my pfaff sewing machine footpedal sticks
Posted on Oct 27, 2009
The pedal on my pfaff 7550 has stopped working. Can you please help.
It could be the machine, itself, or the foot control that is defective. If you can, check the machine with a different foot control to see if that works. If so, then you can purchase a replacement foot control (just look online for Make Model parts). If the other foot control does not make the machine operate, then you know it is probably a machine issue.
Jan 29, 2018 | PfaFF Sewing Machines
Pfaff 6230. Light comes on but no response from pressure foot and lights indicating needle down, etc do not come on
If the work light comes on then power is getting to the machine. If, however, operation of the pedal does not start the motor then that is where the fault is.
Do you have access to another similar machine that you can try your pedal on and that machines pedal on yours.
If not then maybe your local dealer may let you try your pedal on one of their machines.
Oct 05, 2015 | PfaFF Sewing Machines
My pfaff 1222e is running slow
1. Remove any stuck material from the feed dog, bobbin area including the hook (pointed object under bobbin). Lubricate as you go.
2. Remove top and end of sewing machine to look at the motor and belt. Place pressure on the foot pedal. Still slow?
3. With bolt attached to motor release the pressure on the belt. Now, place pressure on the foot pedal. Did you notice any increase in speed?
4. Apply pressure on the foot pedal and simultaneously adjust the motor. Adjusting means tightening of the belt and making it move in a straight line. (If it doesn't move straight it puts pressure on the motor so it will move slow.) When you have adjusted the motor to the right position the motor will be at it's highest speed.
5. If the pressure foot is the problem it will require a pro to take care of it.
Apr 16, 2015 | PfaFF Sewing Machines
My pfaff hobbymatic 955 is not getting any current to the machine through the foot feed wire. Do I have to replace the entire foot feed assembly, or is there an internal pelectrical problem with the...
This is usually the cord to the foot pedal. But could also be a worn out motor or loose connection to the motor.
If you can try another foot pedal that will let you know where to go.
Feb 25, 2015 | PfaFF Sewing Machines
My Pfaff Creative 1475 won't run. The lights are on but when I push the pedal down it doesn't do anything. Please help
there are 2 things it could be
1.the foot pedal could have gone out
2.the motor,,here's how to tell about the motor,, smell the motor & see if it has a smell to it,,if the motor has a smell like old dirty socks or a burn smell then chances are the motor has gone out
the motor would have to be replaced at a repair shop,, the foot pedal you should be able to do your self
websites for parts are--sewingpartsonline.com & sewforless.com
Nov 20, 2010 | PfaFF Creative 7570
Foot pedal does not function on pfaff 7550
May 24, 2009 | PfaFF Creative 7570
sewman7
Sep 20, 2008 | PfaFF Creative 7570
Sewing Machines Logo
74 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
