Question about Kenmore 19606 Computerized Sewing Machine
I have a Kenmore 19606, The bobbin casement keeps jumping out of position then error 5 appears on the screen. Please help. I am hearbroken it is the only machine that I own and have cut out several pattern ready to sew..
  • canuckgir34 Aug 25, 2010
    Machine has not had a lot of use. i did have it repaired by sears for the same problem a year ago. I have tried all the basic stuff.
  • 4,924 Answers
Take the bobbin and the casement out ...and after that open the ring that surround them and take the half shell (semi-ring ) in which the casement with the bobbin fits..and clean the inside for any thread or anything that might be inside...after that put back that semi-ring ...and close the outer ring with care ...and firmly...be careful cause it only has one position in which will fit proper..inser the casement with the bobin again ..and turn the wheel when doing it ..so that the needle to be in upper position ..and a click sound to be made...Than you know it is in the right position ..
When you get the casement out ..be sure you check the thread tension ...which can be adjusted from the side screw oh the casement ..not to be to tide...
After all it is in place ...check the tension on the upper and bobbin threads to be equal by puling them and try to be almost equal ..on the tension you feel ...After that take some piece of cloth and try it out ..
Posted on Aug 25, 2010
  • Kenmore Master
  • 15,557 Answers
You sont say how old the machine is or how much use you have put it through. THe first thing that I would do is replace the bobbins and other associated parts that are removable. They are subject to wear and tear especially if you have a lot of use on the machine. The other thing is that this machine is apparently made by Janome and there are good and bad things about it. One of the bad things is that it gets out of timing and can have problems similar to the one that you are having .The thing about the machine is that it is nice but it has not been very high priced and sold for about 225 USD that is not alot for a sewing machine. IF it is under warranty, I would see about getting it worked on. If it is not then you might want to see what the cost would be to have it serviced by Sears.
Posted on Aug 24, 2010
Free motion quilting on a kenmore 19606 sewing machine
Did you remember to put down the presser foot? I know that sounds silly but that is the one thing people forget the most when doing free motion.
Dec 23, 2012 | Kenmore 19606 Computerized Sewing Machine
My thread keeps breaking. bobbin thread seems to be alright, have changed thread, needle.
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Dec 16, 2012 | Kenmore 19606 Computerized Sewing Machine
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
I have the error message that there is a mechanical problem and the guide says that the machine is stuck??? How would this be repaired?
Good day!
Good day!
Jun 05, 2011 | Feiyue FY100 Computerized Sewing Machine
Thread keeps breaking, sounds like something keeps catching in the bobin area that causes the thread to break on top, skipping stiches also
You could possibly have some burs on the bobbin casing. This will cause threads to break. This is a repair that will have to be done by a professional. OR you could have place the bobbin in backwards. If the bobbin is not in correctly it will not have the right tension and the thread will break. And finally, make sure the upper threading is correct. The thread needs to go through all thread guides and the needle needs to be place in the machine with the grooved side facing you.
I hope this helps. If it does, please rate my suggestion!
Jun 01, 2011 | Kenmore 19606 Computerized Sewing Machine
19606 E1 MESSAGE HELP
E1 error message is a blown fuse problem.
Check out this site it shows you how to fix it http://www.sewingmachineryrepair.com/forums/index.php?topic=79.0
Feb 27, 2010 | Kenmore 19233 Computerized Sewing Machine
Kenmore 158.1703 sewing machine - needle not going up and down
Sounds like your worm drive gear is striped and needs to de replaced. If you twist the handel on the end of machine does the needle move up and down.
Jan 03, 2010 | Kenmore Sewing Machines
Bobbin Casing keeps coming out.
This machine has had 2 different updates for the bobbin case, the second also included a new bobbin visor and the metal bracket that holds the bobbin case in proper position. This sis located at about the 5 oclock position looking straight on at the machine. These new pieces must be adjusted and i am sorry the exact position cannot be explained. It must have just the right amount of movement between bobbin case and bracket. The bracket also must be positioned just right.
Sep 07, 2009 | Singer CE-100 Futura Computerized Sewing...
Stopping
What machine? If it is a 19606/19365 and you are using stitch number 19, then tha twould be normal. It is a tacking stitch. If it is not a electronic, please reply with a model number and I'll try to help!
Thanks,
Bonnie
Jul 29, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
Looped stitches on back
thanks but can't find a screw on the bobbin case, could you be more specific?
Dec 26, 2006 | Kenmore 19606 Computerized Sewing Machine
Kenmore 19606 Computerized Sewing Machine Logo
112 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
