Question about Promac PC10MP Air Conditioner
Have recently moved unit, and misplaced manual. red light that looks like an ac near power button is on, and machine isnt working. plugged and unplugged several times etc. seems to me that we either added water to tray when new or emptied water after it ran. Help, it just turned about 100 here in California and need it. thanks
  • mfplunk Aug 24, 2010
    light is not flashing near power button, just on.... please advise. i don't know what input cold water means? did you see my initial note about the water. do we add water in a tray, or do i recall water drained into a tray? please advise again
    Genius:
  • 1,340 Answers
You probably emptied it.It appears to be a ground unit?First,the tray may need to be in a certain position to enable it by tripping a switch when you push it in so the a/cknows it's there to catch water.Just try pushing it in all the way and wiggling it around,you may hear a click when it hits the switch.Sincethere is a red light on,it has power so it's not the outlet.If the tray trick doesn't work,remove the tray and see if you can find something just hanging down towards the back or something sticking out of the back inside I mean for both.That should be the switch.If you press it and the a/c comes on but doesn't with the tray in,you could just tape it up for now and keep an eye on the water tray constantly until it can be fixed.I hope that's all it is.
If that doesn't work,it will have to be repaired.Looking forward to hearing good news back from you :) Good luck! Greg
Posted on Aug 24, 2010
  • Greg McCarthy Aug 24, 2010
    After I shut down my computer something occurred to me.I have only seen a couple of the floor units.The water tray slot probably isn't big enough for you to reach in and tape the switch if you had to so I guess that's out...sorry :( Greg
    Brigadier General:
  • 3,513 Answers
Hi
Flashing red light indicates there is not enough pressure on the input cold water. It is suggested to contact the customer support or the dealer .
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Two of my smoke alarms went off (no fire/smoke in or near house), one has a green light blinking and one has a solid green light, which need a new battery/reset?
The constant green LED means the alarm has AC power.
A flashing green light every 2 seconds without an audible alert means the unit recently sounded ( was the one activated ) and is now in latching mode to let you know that it was the unit that detected the problem. To clear the latching mode hold down the test button for 5 seconds.
Red LED flashing once per minute means that the back-up battery is connected and functioning.
Red light flashing constantly during alarm means that it is the unit that initiated the alarm siren.
Sep 04, 2014 | Cars & Trucks
Why isnt my tv sound comming out of soundbar
What did you plug into on television. Make sure it is Audio Out could be wrongly connected to component out or Audio in. Have you plugged in and turned on the AC power pack as this could be another possible cause of problems as the sound bar requires power. You may have a faulty AC power pack or power point.
I looked it up on Ilive's web site
32 Bluetooth Sound BarITB183B Press the power button first before selecting Source.Use the Source button on the control unit to switch between optical , aux inputs, line in. If you plugged it into the AUX in on the back you need to select Aux inputs (indicated by a white light) on the speaker. Do you have the user manual if not it is at http://www.iliveelectronics.com/fileuploader/download/download/?d=0&file=custom/upload/File-1380574738.pdf
Hope this helps as I do not have one myself
Jun 13, 2014 | iLive It202b 32" 2.1-channel Soundbar -...
Wii won't turn on.
Reset the AC adapter by following steps below.
1. Unplug the Wii AC adapter at both ends (from the back of the
Wii system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
Jul 22, 2012 | Nintendo Wii Console
I got a compaq c36 it was working fine but now it wont switch on or anything do you now what it could be
1. Plug the laptop into AC power.
2. Take out the battery.
3. Try a different outlet.
4. Look for the light that indicates that the AC adapter is plugged in. If that light isn't on, try plugging and unplugging the AC power jack and moving it around until the light shows its connected. If no light comes on, its possible you have a bad DC jack or the AC adapter needs to be replaced.
5. If the indicator light is on and the laptop won't power on, then it's possible you have a bad switch board or stuck button. Make sure no buttons are stuck. Conversely, push hard on the power button and move it around in order to make sure you're making good contact.
6. If you know the battery has a charge, unplug the AC adapter and connect the battery. If it turns on, then you can be sure you have a bad DC jack or a bad AC adapter.
Mar 01, 2011 | Computers & Internet
Plugged in powerless 360
The power adapter would have gone green when it was working normlly, its what it does, you need to replace the power adapter 'brick' as it is either faulty or was over heated due to travel. Good luck.
Nov 06, 2009 | Microsoft Xbox 360 Console
Wii console isnt working
Have you tired resetting the AC adapter? If not, then try this:
  1. Unplug/remove all accessories from the system (including game discs, SD Cards, memory cards, Nintendo GameCube controllers, hookup cables, the AC Adapter, and Sensor Bar) from the outlet and Wii.
  2. Let the system rest for about 90 seconds. While you're waiting, check to see that controller cords, AC Adapter, and Stereo AV cables/Component Video cables are not frayed or have exposed wires (this can cause the system to shut off); if so, you should replace those parts.
  3. After the 90 seconds, Plug the AC Adapter into the system and directly into a wall outlet, not a surge protector or power strip. Check to see if the power light on the Power button comes on.
Jul 02, 2009 | Nintendo Wii Console
Cannot clear red status light on Compaq rack mount UPS
According to the manual I have, that is a site wiring fault. It means that there is no ground on your AC line coming into the unit.
If you e-mail me, I will send you the pdf of the manual.
Dave
daved07_jd@yahoo.com
Jan 23, 2009 | Compaq R1500 ( 295459-001 ) UPS...
Need a new power cord....misplaced mine...
i did the same thing. replacement at radio shack.
Jan 17, 2009 | Technics SA-EX140 Receiver
Laptop will not turn on.
plug it into the wall , most newer laptops will have a power boost while plugged into AC.
check your power cable receptical on the back of the laptop, these are notorious for getting loose.
check the cable on the ac adaptor, these are bad for getting breaks that you cant see in them (run your hand down the cable physically and fell for any breaks while unplugged, then do it again plugged in and watch for lights to flicker on the computer.
look for the power light on the laptop to come on when you plug the adaptor in. if you get a light on the adaptor and on the computer, then the adaptor isnt the issue.
the next step is checking the power button and power supply.. post what your results are here and we'll move to the next step if not resolved.
Regards!
Oct 29, 2008 | Gateway Computers & Internet
No power to unit
Best suggestion at this time is to have an Authorized SAECO Service Center check your machine. Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
May 29, 2008 | Saeco Vienna De Luxe Espresso Machine
Promac PC10MP Air Conditioner Logo
151 people viewed this question
Top Promac Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Promac Heating and Cooling Expert? Answer questions, earn points and help others
