Question about MSI NF750-G55 AM3 NVIDIA nForce 750a SLI HDMI ATX AMD Motherboard
Motherboard posts, Windows 7 installed, all drivers updated, computer randomly throws up a blank screen while in Windows and I have to reboot. Onboard video problem? BIOS setting I'm missing? MSI NF750-G55 is the motherboard, Phenom II 555 X2 processor, OCZ DDR3 1333 in 2 4gb sticks, Intel 40gb SSD, Seagate 500gb HDD, external Samsung DVD burner, 575w PSU. P.S. This problem doesn't happen in Ubuntu Studio.
5 Suggested Answers
  • 254 Answers
SOURCE: Problem installing Windows 7 on MSI KM4M-V
Id say with those specs Id be sticking to XP mate , win 7 like vista munches resources and without them it can be a pain
it maybe time to shout your self an upgrade , plenty of bargains at the moment.
hope this helped
Posted on Feb 04, 2009
c-tekk
  • 177 Answers
SOURCE: no post to bios on new pc build
FIRST....... Make sure you remove the stock thermal compund (pasty/sticky stuff) from the bottom of the heat sink as well as from the top of the cpu.........
Second APPLY some ARCTIC SILVER 5 compound-ust a thin coat of it over the top of the cpu......use an old credit card.....keep it ff the sides and bottom though......it's important not to use too much........one little tube will do anywhere from 3 to 5 CPUs...!!!
(stock thermal paste/thermal compunds......**** BADLY and can cause a cpu to burn up)
reseat (properly) the cpu and carefull
Now make sure you're 24 pin or 20+4Pin Power connectors are connected, as well as your fans..........disconnect all your SATA Devices, and remove everything but the video card , CPU, and fans.......Now it should post (if all your jumpers are set correctly...........
IF it still doesn't post, remove the video card and reboot.
If it doesn't beep at all......... You have one of 2 things.........A DEAD CPU, or a DEAD MOBO
Posted on Mar 19, 2009
mbase213
  • 728 Answers
SOURCE: nf750-g55 does not post
Hi Jason,
There could be many things that could stop the board from turning on, Determining if it works is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four to see if you get any change. If no change, then I usually get another board that I can test the first four, and make sure that they work. After that, then I say you have a DOA Board
Good Luck
Posted on Nov 10, 2009
bronk50
  • 27725 Answers
SOURCE: Home built pc with nf750-g55,
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your computer hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and to have an end so any faulty leads will end up with a computer error
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the central processing unit
make sure you have enough RAM and the ram modules are securely seated with no dust in the sockets
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
hope this help you
Posted on Sep 06, 2011
My desktop screen goes blank at random. using Windows 7.
Have you got a genuine licence key installed? This could be the problem. If it the entire screen, and not just the desktop background, try checking your graphics driver for updates
Nov 16, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Toshiba c55t-a5222 bios update, after reboot no screen
Did it at anytime lose power during updating? If so, motherboard was damaged and needs replaced. Otherwise, try to boot into'Safe Mode with Networking' and if it turns on, immediately re-install your graphics (video) driver. See this link for instructions on booting in to safe mode on a Toshiba: http://forums.toshiba.com/t5/Windows-7-Knowledge-Base/How-To-Start-your-Windows-7-computer-in-Safe-Mode/ta-p/272525
Feb 01, 2014 | Computers & Internet
I have an fhx2300 monitor and when watching movies on it, random pixel will start turning neon green. The computer will display blue screen saying the driver crashed and then the monitor will display a...
I would go to the Gateway website (http://www.gateway.com/gw/en/US/content/drivers-downloads) and see if your model has a driver update. Drivers Downloads listed for Vista but it should work for Win7-64 bit.
Jun 05, 2017 | Gateway FHX2300 LCD TV
I m looking for sound driver for windows 7 on asus motherboard m2n-mx
ASUS motherboard drivers
Good day,
Click the link below and install the application and then run the program it will scan your computer for possible drivers your computer needs and will download it for you.
Thank you and have a great day.
If you have questions and concerns regarding this post, kindly update this post.
Apr 18, 2010 | ASUS M2N-MX Motherboard
I've format my motherboard with windows7 but unfortunately while it was formatting it reboot and the screen dissapear and just come out a blank screen
A little clarification - I assume you actually mean you were installing Windows 7 on your computer?
If you have a valid Windows 7 CD/DVD, put it in the drive of the computer, restart and enter the BIOS setup screen (you will see instructions on the screen as the computer boots up, might say press "esc" or "delete" key to enter BIOS or something similiar.)
MAKE SURE that the PC can boot from the DVD drive; this is normally an option in the BIOS marked "boot order"; make sure the CD/DVD drive is at the top.
Restart and the installation should start again.
Mar 30, 2010 | Intel DG41RQ Motherboard CPU Bundle - ...
I have a problem with my asus p5vd1-x motherboard. i installed windows 7 os and i don't have sound on my computer. i could not find driver.
Hi, there are many reason that may lead to this problem as windows 7 and new new asus motherboards and compatible which means that generic drivers are installed by windows itself or found on windows update.
Now there are several solutions to solve the problem :
  1. Get on the motherboard manufacturer website to get the driver "click here for the direct link" you'll get the right and updated driver for your motherboard and you just have to setup the application downloaded.
  2. Get a software that automatically detect devices of the computer, find drivers and install them such as driver genius that you may download on it's website : http://www.driver-soft.com/
  3. try to get on sound chipset manufacturer :
    1. Download this driver and unpack (don't need to run setup and it won't help) -> Intel® Desktop Board D201GLY Audio: ADI* AD1888 AC97 Driver
    2. Scan for new hardware but immediately stop the update from Windows Update and instead direct windows to use the drivers you unpacked in step
    Alternatively you might be able to use the RealTek AC97 driver that windows autodetects and installs, but you may have to plug your speakers into the mic jack. If this is not enough detail for you, post back and I'll give you click by click instructions.
    I hope that it will help and don't forget to rate
Jan 20, 2010 | ASUS P5VD1-X (90MBL3C0G0EAYZ) Motherboard
I changed resolution from 640x480 to 1024x768 and all i get now is a blank screen. cannot get back in to change resolution back to 640x480
reboot the computer in "safe mode with networking" by rebooting the machine and during the manufactures name screen, tap the F8 key and you will see the muli-boot menu come up. Safe mode usually loads a resolution the video card and monitor agree on. You may have corrupt video drivers that give the black screen. While in safe mode, go online to windows update and let it scan your system, choose custom installation and look for the optional updates, these will be the hardware drivers you need to update your system. Check them all if you like and let windows install them automatically. Once done reboot normally and see if that clears the problem.
Sep 20, 2009 | Computers & Internet
Hello, I have a Toshiba Satellite R10 laptop with XP and I just Started having an issue where the screen randomly glitches up and either just goes blank or starts flashing different colors across the whole...
Probably a driver issue. Try Windows Update and select custom. Maybe there is an updated driver available, or there could be a driver conflict (wrong driver installed). At worst, it could be an issue with your screen itself or possibly even the motherboard. But I doubt it. If you can't find anything there, try http://www.toshiba.com
Jan 29, 2009 | XFX GeForce 6200TC Graphic Card
V2dp and geforce vid card
You need to re-install the motherboard drivers for the onboard devices.
Sep 01, 2008 | Jetway V2DP Motherboard
MSI NF750-G55 AM3 NVIDIA nForce 750a SLI HDMI ATX AMD Motherboard Logo
54 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
