I currently have dual split units (Trane XL80 & XR13) heating and cooling the house. One of the XR13's is not working properly. This is what I observe. The XR13 in question is running --the fan is running-- but, I am not getting any air flow from the registers. The XL80 that it is mated to is in the attic; I noticed that there is a blinking red light that is visible through a small clear porthole on the side of the furnace. \r\n Regards, Ralph in Bellflower, CA.
  • 43,501 Answers
Check how many times the light is blinking... it will flash a series of blinks and then pause...and flash the series again...
Then remove the cover nad insdie it will tell you how to interpet the blinks and then you will know why it is kicked off...
heatman101
Posted on Aug 24, 2010
Fans kick in after just a short run and heaters not working
Is the heater a gas furnace? Do you know a brand name . Possibly a model number. If a Trane a serial number too. Why type of unit package or split system. Can you be more specific?
Feb 20, 2017 | Heating & Cooling
Trane XL80 downdraft furnace intermitant eratic ignition
Erratic ignition like what exactly? Comes on runs for a few minutes or seconds then turns off gas then tries again? Or erratic it won't fire the gas at all? Can you be more specific?
Feb 17, 2017 | Heating & Cooling
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Trane xl80 blower working intermittently
hello Miss/Mrs/Mr,
I have the furnace trane xl 80, when I turned for heat everything working but only blower motor was not running, I wait for 1 minute all system suck down? I guess the capacitor blow out, that the reason why blower motor was not running
Please email me that is the
Jun 24, 2012 | Heating & Cooling
I have a trane XR12 Heat Pump. The cooling fan on the outdoor unit does not run nor does the compressor. The fan motor heats up and hums. I am guessing that the problem is the start capacitor on the fan...
Hello Rich,NO you have a dual capasitor that runs both fan & compressor motors.Shut it down and let it cool off.You need the uf rate numbers & the volt rating of the existing cap (printed on the side)to get EXACT replacement.The wires plug in to the top termanls C, HERM &FAN.Worth fixing good luck.
Jul 29, 2010 | Heating & Cooling
LG Art Cool, 2 splits. Error code CH7
Multi Splits and Multi V = indoor unit is set to run in a different mode from the master indoor unit. Set ALL indoor units to cooling or ALL to heating to clear.
Splits = Compressor Over Current (CT2)
Jul 09, 2010 | LG Art Cool LA121CNP wall/window Air...
TRANE 1984 Home A/C Where are How to Clean Coils inside House
the best thing to do it with airhandler shut down at breaker. 1st soften dirt and crud with 409 or different brand. 2nd take a wire brush and clean in up and down motion following the fins on coil.3rd rinse with spray bottle . this is the best you can do without coil removal.
Jul 02, 2009 | Heating & Cooling
Programmable T stat
your trane heat pump energizes the reversing valve with O - orange y - is to turn on the unit make sure you have your orange wire hooked up and the tstat programming set to heatpump otherwise your reversing valve might be bad
Jun 30, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
272 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
