Question about Poulan Garden
My Poulan 14.5 hp riding mower won't start. Fuel line was clogged initially, but I replaced it. Fuel gets to the carb but will only run if I use carb cleaner or starter fluid. How do I get fuel to flow inside the carb. Model # 27149
5 Suggested Answers
01fordeb
  • 1033 Answers
SOURCE: have a poulan 38
The float and needle need to be replaced in the fuel bowl. What is happening is, the float is stuck upward raising the needle out of the hole completely causing the carb to over flow. A kit can be bought for $5 or so. Easily replaced. You can also try cleaning it with a mild solvent, but usually when the float messes up it's best to replace.
Posted on May 27, 2010
SOURCE: I have Poulan model 27149 riding mower. Shifting
Mower stops after running 30 minutes COULD IT BE THE SOLENOID VALVE ON CARB FOR GAS LINE
need tune up kit #5122A
Posted on Aug 07, 2011
  • 6468 Answers
SOURCE: I have A craftsman Model 917.273470 with a Kohler 20 Hp V-Twin. It will run if I spray gas in the carb. Drained old fuel, replaced fuel filter, checked gas flow into carb with pressure guage, Cleaned
check the solenoid on the bottom of the carb check for movement and power if it moves and has power open the carb and clean it
Posted on Apr 19, 2012
  • 6468 Answers
SOURCE: John Deere L110 won't start.
check the solenoid on the bottom of the carb see if there is power if no power check the safety switch on the brake/clutch if there is power remove the solenoid and put power and ground to it to see if it opens if not try and clean it with carb cleaner if that works and opens remove the bowl from the carb and check the needle valve on the float make sure it moves
Posted on Sep 03, 2012
Clogged fuel line on craftsman riding mower
Remove fuel filter then let fuel run till good. You can use a piece of
wire if doesn't run. Replace filter, unhook fuel line carb. And let
run.
Oct 15, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I got a poulan po1742stb riding mower with a 17 hp briggs n stratton engine it was my dads and it hadnt cranked since he died which was bout 2 years ago so i had to replace the ignition coil and my wiring...
Thanks for stopping by...
When you said "cleaned the carb" - did you disassemble, and clean - or just spray carb cleaner into it?
Sitting for 2 years - the additives in the gasoline can leave a varnish that will clog the tiny jet orifice in the carb bowl.
You'll need to disassemble, and clean out the jet with a wire.
Popping and sputtering can be caused by a few things:
Old Gas - drain and refill with fresh.
Dirty Air Filter - Check and clean/replace it.
Poor Fuel mix/ratio - clogged Carb Jet or sticky butterfly.
Poor Spark - check/change the plug.
Fuel Vaccuum - remove the gascap - and start... the vent hole may be clogged. Clean and/or replace it if it starts running better with the gas cap off.
Clogged Fuel Filter/inlet screen - backflush the tank and the debris should wash back into the tank. Rinse out and re-install.
This is most likely a fuel delivery or spark issue.
Change the fuel and plug first... and give the carb a GOOD cleaning... then re-check.
Thanks!
Sep 22, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a poulan weedeater it will start but will not run. how do i adjust the carburetor?
YOU WILL HAVE TO CHECK ALL THE FUEL LINES AND MAKE SURE THAT IT IS GETTING FUEL FROM THE TANK,THEN CHECK THE ADJUSTING SCREWS ON THE CARB,LOW RUN SCREW AND HIGH RUN SCREW
Sep 01, 2011 | Poulan Garden
Starts then cuts off and won't restart
Hello; This is likely a carb problem or clogged fuel line or fuel filter if it has one. If it runs for awhile before cutting out, check your gas cap. They all have some sort of vent to let in air as the fuel level goes down. If the vent is clogged, the carb can only **** out the gas for seconds or a few minutes. john
Aug 15, 2011 | Poulan Garden
Mower will not stay running. replaced fuel line. didnt work. as long as i spray starter fluid in air intake it will run
I would first check to see if your fuel pump is pumping any fuel. You can take off the fuel line going the carb and turn the motor over and you should have fuel coming from the line if you dont then the fuel pump needs replaced. If you have fuel at the carb then you have a clogged up carb. GOOD LUCK
May 03, 2011 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Have a poulan 38" 13.5 hp riding mower. replaced fuel line, but gas keeps filling up the carburetor ?
May 27, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Identifying the engine used in a Poulan PO16542 mower
I suggest removing the carb and taking it to an authorized B&S repair shop, they will be able to I.D. it.
Apr 26, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan Pro 18.5 HP Intek engine trouble
Might be fludding..
If there is a bowl on the carb, pop it off and check the float.. Check for fluid inside the float. If the float is holding any fluid - its bad..
Srpay carb cleaner in there..
Clean the bowl..
Jul 09, 2009 | Garden
No Gas
Most probably the carb restricted by varnish, trash or rust. Need to clean carb. You'll probably see the problem when you remove the bowl.
Jul 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
79 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
