Just purchased this lap top and pushing volume buttons is not controlling any thing. what do i do
    Problem Solver:
  • 16 Answers
Make sure you have the "Quick launch buttons" software installed
Posted on Aug 24, 2010
The sound on the TV Model PBT-26000W is not good. There is a symbol top center of the TV (not mute-bottom) with crossed speaker. How ca I remove this symbol and get normal sound.
Use the remote control,look for a button said MUTE.Push the button on the remote to release it.Or push the volume button + - to release the volume control.
Oct 11, 2010 | Prosonic PLTV-30 30 in. HD-Ready LCD...
Aspen watch
this should work with your aspen watch let me know if it doesn't
http://dive.scubadiving.com/members/gearreviews.php?s=593
Quote
For the alarm: If you want to use it (I think both it and the light use battery faster than when not used), you set it by pushing mode button twice, as indicated above, then go to hour or minute setting by pushing the lap/reset button, and advance to the time you want by pressing the start/stop button. Pushing mode will take you back to normal time again.
To turn alarm on or off, hold lap/reset button in and at the same time push the start/stop button. Alarm icon will show on or off. When you release the lap/reset button, it will revert to normal time.
If the alarm is on, at the designated time it will start beeping for awhile or until the lap/reset button is pushed (off) or start/stop button (snooze).
Aug 08, 2008 | JCPenney Armitron Sport Link Bracelet...
PROBLEM IS SWITCHED ON TV ATOMICALLY CHANGING CHANNELS AND VOLUME NOT ABLE TO OPERATING.....
Stay calm, first of all. Try not to get frustrated. You most likely have stuck buttons. The first thing I would try is to take a toothpick and gently pry at the buttons that aren't working. If that doesn't work, take the remote apart and push from the inside on the buttons. If that doesn't work, you may need to purchase a new remote, at walmart for maybe about $8.
Oct 06, 2010 | Televison & Video
The remote actions things twice with one button push
technically we call it debouncing it causes due to the faulty microprocessor in remote also it can happen due to faulty carbon contacts of remote below buttons.the solution to this is to replace remote but before that do one thing 70% THIS WORKS open ur remote then take a dry cloth & clean the surface below buttons if u r lucky then remote will be OK
Mar 14, 2010 | Logitech Harmony 550 LCD Remote Control
Volume trouble
The top button on the control surface, the one with the green flashing LED, is the volume control. When the unit is "ON" pushing the button up or down raises or lowers the volume, simple. When you connect it to the charger that same green light will turn red while charging. If you push the top button forward (up) at the same time you press the lower button (power) the LED will flash 1-3 times. Three flashes is fully charged and one means it's getting low.
This is a great head set. I just sat on mine and broke the ear piece. I'm looking for another as we speak! It's worth more than it's current retail price by far!!!
Jan 27, 2009 | Body Glove Earglove Bluevoice Bluetooth...
How do I turn on the speakers on my HP lap top?
There are buttons near the screen that should do this. Or it might be that your sound card is muted in which case click on the speaker icon in the bottom right hand corner and when the volume control comes up click on the mute button to activate them. hope this helps
Oct 07, 2008 | HP Computers & Internet
How do I work the lap timing function work?
hello,the buttons are numbered 1-4
clockwise-top right button #1
bottom right button #2
bottom left button #3
top left button is #4
in normal time push #3,then #1 to start and stop lap time.
for lap time press #2 while chronograph is running,it keeps running while lap time is displayed push #2 again to return to chronograph time display,to clear push #1 to stop then #2 to clear.
Sep 03, 2008 | Timex 1440 53591 Sports Quotient...
Volume Control
The volume control shaft lube, over time and heat exposure, will flow down and corrupt the contact between the volume twister and the spring loaded sensor. Pull the cover off the tuner, locate the volume control and take out the two screws holding it in. It looks like a small circuit board with the volume twister attached.
The base of the twister is hooked to the circuit panel by four metal tabs. Pry these guys gently away and pull the twister free. There will be a metal disk at the end of the volume control shaft, and will have a goopy lube residue on the face of it that can be cleaned with electric contact cleaner or some other kind of solvent. Wipe it clean,(do not immerse) reattach, and test. Worked perfect for me.
Good Luck,
F
Feb 25, 2008 | Pioneer VSX-D509S Receiver
Timex expedition
HI
HERE IS SOME STEPS FOR YOUR DOUGHTS......
Set the chronograph. Push the bottom left button until you see the word "CHRONO" on your watch. Press the top right button to pick "Lap" or "Split." Press the top right button to start or stop the timer.
Press the bottom left button to see your lap or split time. Press the bottom left button to pause the timer. Press the top right button to start again. When you're finished, press the bottom left button to stop timing. Push it again to reset it your chronograph to zero.
THANK YOU
Dec 12, 2007 | Timex Digital Expedition watch
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
