Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Stand by timer continiously blinking there is sound but no picture pls help, it was perfect in the morning.
Hey i had a similar problem with my television if your comfortable opening your tv "i would if it needs to be fixed" open it up there should be a red cable running from the electrical components to the actual tube there is where more than likely the problem is located, with my television it was that what i did to solve this problem is tighten that connection up and make sure it is closing the circuit so to speak
so if you've gotten this far opened your tv and located the wire try pulling on it not to hard obviously but give it a nice pull and have someone turn on the TV while doing so remember don't touch any electrical components and always ground yourself before embarking on any electronic journey if this has any effect on the television the next step is figuring out a way to tighten this connection up obviously we cannot solder or do any of the sort with this type of connection so i would advise to stick a small enough object you can fit next to the cable now we don't want to stab a hole in the cable just wedge it in next to the cable fiddle around with it until the picture is crisp clean and perfect and voila....... it worked for me and has been working for over a year now remember use your head don't stick anything that might cause interference or conduct electricity
and there you go noobinuity at its finest
Posted on Aug 25, 2010
Cable hooked up right...turned on this morning sound no pic
Ur tv been in use at least 1 1/2 or 2 years.On about 4 or 5 hours a day on this tv?The LED light indicator "LAMP" flashes?The projection bulb life is over.Require a new bulb.
May 27, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Sony KP-41T65
is there a cadence to the blinking timer light?
Jul 17, 2009 | Sony KP-41T65 41" Rear Projection...
Tube 27" sony tv, stand by timer light blinking red?
It has a faulty power supply or processing boards. Must take to agents to sort out. Nothing you can do on the outside.
May 12, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
SONY WEGA TRINTRON MODEL KV36FV15 RED LITE FLASHING
The model number is KV-36FV15 and blinking is constant no pause
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
2000 Sony Trinatron #KV-36FV26
IF--- You have 3 video ics located on CRT broad # TDA6111Q ,if only one of them is shorted set will not come on these ics will kill the high voltage, there for keeping set off.
May 18, 2008 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony trinitron tv
If you have sound but no picture it means that your power supply and tuner are working correctly. The number of times the timer LED blinks is the code for the problem with the picture. The computer will stop the picture and blink the timer LED if the vertical circuit stops working, if the picture tube is too weak or if the horizontal sweep has stopped. The set should be serviced by a qualified tech familiar with Sony sets.
Sep 03, 2007 | Sony WEGA KD-34XBR970 34" TV
No Picture
Give more detail is sound from your tv or stereo system for example, what lights are blinking on the front panel?
May 20, 2007 | Toshiba 43A10 43" Rear Projection...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
24 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
