You can download the device drivers from ASUS WEB site. Select your model motherboard/computer/laptop, and make sure you select drivers that matches your Windows operating system. Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
first make sure your wireless adapter is not disabled you can check it by running rfkill list in terminal if it is type sudo rfkill unblock wifi [second you can try activating and deactivating by typing sudo ifdown wlan0 and sudo ifup wlan0 me personly have kept to 10.10 the 11.04 seem to have a few glitches you can also check for additional drivers
please make sure that all the drivers required on your computer is installed specially the chipset driver, display drivers, and any device thats on your pci slot.
Your device drivers aren't compatible with windows 7. Can you connect to the internet via cable?? If yes run windows update, this should find updated drivers to run with windows 7
Right click-mouse over My Computer
Properties
Hardware(Tab)
Device Manager(button)
Click [+] next to System devices
right-mouse on CPU to AGP Controller (or whatever your controller is called, mine was SiS AGP)
Update Driver(button)
Select Install from a list or specific location (Advanced)
Next(button)
Select Don't search. I will choose the driver to install.
Next(button)
Select PCI standard PCI-to-PCI bridge
Next(button)
Finish(button)
Reboot.
You have to install the drives again download from here Or use your motherboard cd If an error occurs during the installation make sure to remove the device from the device manager Reboot Re-Install the driver Remember- Don't remove drivers which are related to The Power Options
you would need to get all the drivers for your laptop from the IBM website and install all of them. If you cant find them or need further help please post back and let me know.
The wireless is not going to turn on and off via the switch properly until we get the drivers loaded to make it work. There are 3 possible types of wireless card it could be, so we have to find out the exact model number of your system. On the bottom there should be a label that has a P/N or part number listed. what are those numbers. Here's an example of the label:
we need the info listed for #1, #2 and #3. Then we should be able to determine which adapter you have, and then we can (hopefully) find some Windows XP drivers for you.
