Question about Marantz SR6001
Sr6001 standby power light keeps flashing - Marantz SR6001
    Brigadier General:
  • 3,513 Answers
Hi
Try disconnecting all the speaker wires from the back and connections and try to turn it on. (Just to be sure that no stray wires have touched any speaker terminals shorting the amp out.) Then plug the power back in at the wall and try to turn it on. Again if it works then connect the speaker wires being careful not to touch have any stray wire touch other wires for each connection. If it does not turn on after removing all the connections then you have a bad receiver.
However there is no way that you can disable protection mode that Marantz or Authorized servicers are allowed to give out. The early versions of this model all you had to do was unplug for a few minutes then plug back in and unit if it did not have blown amp unit would power up and work fine. But if amp had failure it may cause more parts to fail so they changed software to not allow users ability to disable protection. Send to Marantz Authorized servicer for them to check for amp failure or mayby they just have to disable Protect Mode.
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Aug 24, 2010
Standby time light on and keeps flashing
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
May 21, 2011 | Sony FD Trinitron KD-36XS955 36" TV
Standby light keeps blinking but no picture
May 01, 2011 | Sony KP-53S65 53" Rear Projection...
Tv wont power up Standby light keeps flashing.
First step in any Sony LCD projector repair is bulb or lamp replacement. Fixes 95% of problems.
Taking apart and trying to measure things without a known good bulb is a waste of time and effort.
easyab
ConvergenceRepair.com
Feb 26, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
No picture
(i) Disconnect all the cables from the TV including the power cable then reconnect them after a few minutes.
(ii) Make sure that the power cord from the TV is directly connected to a functional wall outlet.
If the standby light keeps flashing then service will be required.
Aug 24, 2009 | Sony KP-53V75 53" Rear Projection...
Reciever just shut down didn't notice the protect word come up due to it being in a audio cabinet, but now the standby light is flashig and the receiver does nothing.
If it was in a cabinet then it probably got too hot. If you listen at a louder volume for a long period then operate it with the doors open.
Unplug it and let it sit and/or hold in the power button until it "clicks."
Jun 04, 2009 | Marantz SR6001
Marantz sr6001 amplifier flashing on standby continuously
hi there
check settings for this configuration ......if you have a subwoofer in the settings, for best overall results choose subwoofer yes, and set main/center/surrround to small....if no subwoofer set left/right speakers to large and small to center, if there is no loe frequency effect (lfe) going to the subwoofer it will go into standby....hope this hlps ....shia
May 28, 2009 | Marantz SR6001
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
I have exactly the same problem! Sometimes when I turn the input dial it comes back on but this time it is out for good. I have tried re-wiring and unplugging etc. nothing seems to work.
Jan 21, 2009 | Marantz SR6001
For resetting sr6001: When power lights blinking, press "clear" + "pure direct" + "7.1 ch input" simultaneously for 3 seconds.
iskender
Nov 10, 2008 | Marantz SR-7200 Receiver
Try pressing the power, and multi speaker button at the same time. But first turn the unit off...then press the above buttons at the same time...This is for the SR6001... GH
Feb 16, 2008 | Denon DRA-395 Receiver
Reciever not working
Are all the speakers GOOD and all connected right?
If so then you have at least one blown output amplifier module.
Feb 16, 2008 | Sony STR-DE345 Receiver
Marantz SR6001 Logo
249 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
