Question about Epson Stylus 880 InkJet Color Printer
RE: Epson stylus Color 880 there a way to manually move the ink tanks to change the black ink cartridge? Utility Shows still ink but no black ink after many nozzle and head cleanings. Must be old and dry ink. Don't want to force it over.. ay solutions?
  • 514 Answers
You will need to press and hold both of the ink buttons down, (sorry, don't have mine right in front of me) it will take about 5-6 sec.s for it to start moving over (have the cover up for this) then just lift the tab and replace, it will cycle for a few sec.s then should start to print just fine. if that doesn't work then goto this site http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=FAQ&oid=14374&prodoid=11473&foid=31730
and it has details for you.
Posted on Sep 14, 2010
Epson Color Stylus 880 not printing, blank pages only
With some printers they need to be the recommended brand of ink cartridge. Are you using Epson's own cartridges? If not might be worth changing to them. It sounds as though the issue is with the cartidges and not the printer itself. Hope this helps.
Oct 28, 2016 | Epson Stylus 880 InkJet Color Printer
Have changed all cartridges on epson nx400. test shows 3 ink cartridges printing, except for the black ink. have run clean head utility, ink has charged. downloaded and installed printer driver. Found an...
Hi
The ink reservoir doesnt have to be completely empty to fail. Replace the cartridges. Some of the jets or all of them may be clogged especially if you have not used your printer in a while. If there are cleaning instructions in the manual clean the jets and then try to print from the printer's self test
Goodluck
Mar 09, 2011 | Epson Stylus NX400 InkJet Printer
I changed the black ink cartridge but the printer prints blank pages. I have tried cleaning the printer but no luck. What can I do? (epson color 880)
reinstall your driver also check for driver updates
once unistall the driver from the system and restart and install it again and try
Mar 08, 2011 | Epson Stylus 880 InkJet Color Printer
Printer not working so put new Color ink in - red light is on the black ink. Changed printing preferences to Color Ink and deleted all documents in queue and also turned off computer and still the printer...
part of your prob is that the way ink jet printers work, (according to the tech support training that I rcv'd about ten yrs ago from Canon) is that the printer "builds" the image or character by adding color to the black ink (for most of the jobs) in order to create "depth", so you will need to replace or (HINT: you can sometimes reset the cartridge by lifting the locktab and then reseating it) using the utility to replace the black cartridge. good luck!
Jun 13, 2010 | Epson Stylus 880 InkJet Color Printer
Epson Stylus 880 - how do I get it to allow an ink change when the low ink indicator is not lit and I hold the button down but the carriage refuses to locate to the left for ink cartridge removal?
Go thru your utility replacement. That should do the trick. It might not look like mine, but similar.
If you find this information helpful, pls rate me. If you need more help let me know.
Thans and good Luck
Feb 07, 2010 | Epson Stylus 880 InkJet Color Printer
Carriage cycles normally but no ink on paper.(Stylus color 880)
Turn off printer. Open Case. Move head carriage to parking position. Do suction from outlet pipe of head cleaning mechanic. It's for checking head. is there ink out? If printer not used for long time, may be ink inside head dried. Utility screen just show estimated not actually. If head clog, and do head cleaning more 5 times, screen show ink nearly out, but actually ink tank nearly full.
Jun 28, 2009 | Epson Stylus Color 760 InkJet Printer
I have a epson stylus printer C65 series. I ran out of black ink so i changed the ink cartridge and it will only print colour not black now.
I have an Epson stylus 6000 series, second hand but was working just fine. I changed the ink cartridges and now the color won't print. Utilities shows all cartridges full, but only black and pale green-blue print. While it was printing color it was drinking the ink, but that's another story.
Yvonne
Aug 09, 2008 | Office Equipment & Supplies
Ink not empty
You have confused the software in either changing a cartridge when not required or having a chip failure whilst changing multiple cartridges.
Full info on how to get out of this is on my site.
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Apr 13, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson 880
if red ink light is still on, check that the lid for the cartridge is fully seated
Dec 19, 2007 | Epson Stylus 880 InkJet Color Printer
Epson Stylus 880 InkJet Color Printer Logo
559 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
