Question about GE Dryers
My ge gas dryer works but no heat - GE Dryers
  • GE Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 24, 2010
futureloginn
  • 734 Answers
SOURCE: ge gas dryer
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
SOURCE: gE GAS DRYER DCLR333ETOWW
need the location for the operating thermostat for model GE Dryer DCLR 333 ET OWW This is a Three wire thermostat that advances the timer in the auto mode heat
Posted on Jan 27, 2009
TheMobilian
  • 8220 Answers
SOURCE: Gas dryer won't heat up
Check the flame sensor for continuity(if open no heat)
Check the ignitor for continuity(if open no heat)
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 08, 2009
burdfrenzy
  • 348 Answers
SOURCE: GE DSXH43GV0WW Gas dryer
You need to replace your igniter coil element. That is what ignites your burner.
Posted on Oct 15, 2009
heatman101
  • 43501 Answers
SOURCE: Dryer not heating up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
Posted on May 25, 2010
GE DBLR333GGWW gas dryer runs but no heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 19, 2011 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Ge profile gas dryer...i am not getting heat
heatman101';';
Jun 12, 2011 | GE Profile DPSB613G Gas Dryer
GE Adora, gas front loader, dryer will not heat.
check out this electric no heat tip...
heatman101
Jan 31, 2011 | GE Dryers
GE Gas Dryer not heating
heatman101
Jan 17, 2011 | GE DWSR405EBWW Electric Dryer
I have a gas GE dryer DPGT750GCWW ;- it only heats occasionally. Sometimes it will work all day, other times it will heat one load and won't heat up for the next load. The vent has been cleaned...
heatman101
Dec 18, 2010 | GE DBXR463GB Gas Dryer
I have a GE DPGT750 Gas Dryer. The dryer will not heat up. Air is blowing out of the exhaust outside. However, the air is cold.
heatman101
Aug 28, 2010 | GE DPGT750GC Gas Dryer
My ge dryer wont heat up
heatman101
Jul 08, 2010 | GE DWSR483GB Gas Dryer
GE DBSR453GB Gas Dryer doesn't dry on 1st cycle.
heatman101
May 30, 2010 | GE DBSR453GB Gas Dryer
heatman101
May 24, 2010 | GE DPSE810GGWT Gas Dryer
GE Profile gas dryer tumbles but NO HEAT, not ignitor
heatman101
Apr 30, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Dryers Logo
121 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
