Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
I received an F7 message on my Jenn Air wall oven accompanied by a beeping sound. I recently changed the broiler coil?
  • 530 Answers
Sounds like a bad keypad
Posted on Aug 24, 2010
F7 code flashes on jenn aire 27 inch wall oven
The F7 code indicates that the touch pad either has a "stuck" or shorted key. Depending on the oven model, you either need to replace the touch pad or the controller (clock) and the touch pad. (Some Jenn Air appliances sell the two as one unit.)
Please add a comment with your model number to get additional information on the availability and price for the parts. (Parts may be available from a number of suppliers, including jenn-air.partselect.com.)
I hope this helps.
Mar 01, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
The oven keeps beeping and displays "F7" as an error message.
Hi
Thanks for using FixYa. Error F7 on your oven means that the keypad is shorted or stuck and to resolve this issue you’ll have to replace the Electronic Range control (ERC). Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 25, 2010 | Jenn-Air JMW9530C Stainless Steel Oven
I have a Jenn Air Oven micro combo wall unit.The oven shows an error code F1/F7 with continuous beeping. I have to turn power off to get rid of it. But then I cannot use the mocrowave-any solutions?
Hello- The code described F1/ F7 indicates a 'stuck' key on the control panel. The problem is fairly common, and is not caused by computer. The panel is actually more expensive than the computer. On site diagnosis is needed to confirm. The switch is on a circuit board behind the panel and is not serviceable. Find a good service tech in your area to check it out. Wish I had good news, but I installed several of these under 1 year warranty period.  So- let me know if this info helps- have more if needed.   Thanks- Ed
Mar 17, 2010 | Jenn-Air JJW8530C Expressions Collection...
Jenn Air oven keeps beeping F2 and the upper oven broiler won't shut off. We do not have a manual. Please help!!! Briezee85@netscape.net (925) 672-1279
Sounds like a welded relay on the control board. You can replace the board or have the board repaired for much less expense.
Feb 20, 2010 | Jenn-Air JJW8230D Electric Double Oven
Beeping and F7 when cleaning
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jan 07, 2009 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
170 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
