Question about Diamond Multimedia ( VC500) Video Capture
Hey guys i just buy a diamond vc500 i connected everthing but when i open the one touch video thing its a black screen theres like green blue lines moving around idk im using windows7 ultimate 32-bit i already tried installing everything via WINDOWS XP BUT STILL NOT WORKING IDK PLEASE HELP I REALLY WANNA RECORD MW2
Dats wat hapened 2 me n i want 2 record mw2 wat system u got
Posted on Sep 07, 2010
Diamond VC500 Capture Card Wont Record!?
Windows bugs... I would first remove the card and software and then reinstall. Update drivers under system devices. Try again. There may also be a menu to enable recording, allocate hard disc usage for recording etc.
Sep 05, 2012 | Diamond Multimedia ( VC500) Video Capture
Diamond VC500 no video formats and black screen, not recording
Had this exact same issue, tried uninstalling, reinstalling, unplugging, plugging back in, updating drivers, etc. with no success, but it was all resolved instantly when I switched the device to a different USB port. The port I was using before works fine (in fact my keyboard is now connected to it as I type) but maybe it is a different type of USB port, and not the one the video capture device is looking for. Hope this helps others with the same issue.
Jan 08, 2012 | Diamond Multimedia ( VC500) Video Capture
Diamond vc500 "usb device not recognized" i have a
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps you
Oct 21, 2011 | Diamond Multimedia ( VC500) Video Capture
I have a diamond video one touch and I have two concerns. Sometimes when I capture video there is a green bar at the bottom and sometimes not. Why Also I would like to take a snapshot from time to time,...
I, too, have the green bar at bottom problem occasionally. It only appears upon loading. When it does, I have been able to get rid of it by closing the program, then re-opening. Invariably, thus far, the green bar is gone upon second loading. Annoying, but the product has worked for me now for several weeks of heavy use.
Jan 06, 2011 | Diamond Multimedia ( VC500) Video Capture
No signal from Diamond VC500 Capture Device
I have a similar problem. Sometimes it works fine, but it will often have sound but no picture in the box. Other times, there is no input signal showing when I click on the gear wheel to adjust settings. There is no rhyme or reason to the missing picture. Whe I play it back, I do have the picture - usually.
Jul 18, 2010 | Diamond Multimedia ( VC500) Video Capture
Diamond VC500 One Touch Capture not recording properly.
Try turning off your screen saver. The recorded file will reset to zero whenever the screen saver kicks in.
Feb 25, 2010 | Diamond Multimedia ( VC500) Video Capture
I get the blue screen of death whenever I try to use my VC500 One-touch Capture Card. An hour ago, the card was working fine, but 10 minutes ago my whole computer started to get really slow once I...
The first thing I would try to do, is to download the latest drivers from the website and see if that helps.
if the computer is going really slow, you might also have spyware or virus, you may want to check for that.
you can download spybot search and destroy at www.safer-networking.org
or spybot at www.lavasoft.com
they are both free
you can also d/l antivirus software at www.eset.com good for 30 days
thanks
Feb 05, 2010 | Diamond Multimedia ( VC500) Video Capture
Diamond VC500 is not recording my Xbox 360
Mine does the same thing. I think that the problem might be that you have to go to the yellow gear thing and you have to change the recording format to DVD and you have to change the video format to NTSC_M. And make sure you have all of your hardware and your y splitters connected right
Jan 20, 2010 | Diamond Multimedia ( VC500) Video Capture
Diamond Multimedia ( VC500) Video Capture After I installed the program files from the disc and set up all the three cables for the audio and video, everything is hooked on right and tight but once I plug...
I was having this problem also. I originally plugged my 3 video cables into the VCR outlets in the front of the vcr. I finally turned the vcr around and found two other sets of video out plugs. One was to a dvd/dvr and the other was a vcr out. I took the plugs from the front of the vcr and plugged it into the dvd/dvr out and it worked! Good luck with your problem. Hope the resolution is just as simple.
Mar 16, 2009 | Diamond Multimedia ( VC500) Video Capture
How to set up one-touch video capture vc500
You can use either the S-video or the RCA video connector. I don't think you can use both at the same time but I haven't tested that. Also, if you use the S-video adapter, it has no audio so you also have to use the RCA audio connectors when using S-video. Hope that helps...
Aug 26, 2008 | Diamond Multimedia ( VC500) Video Capture
Diamond Multimedia ( VC500) Video Capture Logo
1,014 people viewed this question
Top Diamond Multimedia Televison & Video Experts
Hipolito Jimenez
Hipolito Jimenez
Level 1 Expert
A Vlad Fuica
Level 1 Expert
Are you a Diamond Multimedia Televison and Video Expert? Answer questions, earn points and help others
