Question about HP P4515n LaserJet Printer
Hi, i'm working with an HP P4515n Laserjet Printer with the msg "Insert Black Cartridge". The problem started with the original toner that comes with the printer, but i've also tried it with a new one and its showing the same msg. The service manual doesn´t mention any part replacement but the HP 4200 service manual says "after changing the toner if the problem persist, replace power suppy"...Will that work with the P4515n printer?
  • malakir Aug 26, 2010
    Did the power off reset and the cold reset...nothing changed. Any other suggestions? or is it time to order the power supply?
    Thanks.
    Genius:
  • 1,478 Answers
Before you follow that instruction, i will advice you reset your printer first, because problems like this happen, it is first advice to try reset the printer. Power off the printer and power on back, while the printer is warming up. remove the plug from the AC unit and wait for some minutes before plugging it, plug it back, see if it fix the problem, or you follow the reset instruction on the printer manual, if the problem still persist, you can now replace the power supply.
Take care.
Posted on Aug 24, 2010
  • Jimoh Adeleke Muyideen Aug 26, 2010
    Since you have carried out all the reset, and not still solve, i will advice you let a repair person help look into it and also order for the power supply.
My hp p4515printer has an error of 59..40 & 59.50my hp p4515printer has an error of 59..40 & 59.50
59 errors are caused by problems with the cartridge drum drive motor. In my experience, this is most often caused by a bad cartridge that is frozen and does not rotate. Try a different toner cartridge as this will usually solve the problem.
Aug 04, 2014 | HP P4515n LaserJet Printer
4515 prints blank pages
1- check the Toner cartridge is installed correctly , try to uninstall toner then installing again , then tell me what is happen with you
Mohamed Hejazi
Afaqnama Libya
IPg@hplibya.com
Mar 20, 2013 | HP P4515n LaserJet Printer
Insert black toner hp laserjet 2055d
Assuming the printer already has a CE505A and CE505X installed this would either be a error with the toner cartridge or the corresponding contacts inside the printer.
If you have just changed the toner then I would advise re-installing the old cartridge to see if the error disappears/changes. If however the cartridge has been in the printer for a while i would recommend removing it resetting the printer and them firmly re-installing.
If this doesn't help I would recommend calling HP or a printer technician.
Sep 13, 2012 | HP LaserJet P2055d Printer
Hp lajerjet 2420 install black cartridge msg after toner refill and new toner insert then ok
  1. The cartridge toner (q6511A or X) is damaged.
  2. The smart chip on the toner cartridge doesn't work.
Jul 20, 2011 | HP LaserJet 2420 Printer
I have a issue with hp laserjet 1022 having cartridge missing error please provide some needful helps
Hi
Make sure you installed HP toner cartridge for your printer. and Insert is correctly into the printer. Try to use the old toner cartridge and check if this is the problem.
Just replace new toner cartridge and i might solve your problem. Regards
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 11, 2011 | HP LaserJet 1022 Printer
PRINT FADING ON RIGHT HAND SIDE WHILE BLACK CARTRIDGE SHOWS FULL.
your cartridge is third party toner insert new hp original cartridge before cleaning
Jun 23, 2009 | HP Color LaserJet 2600n Printer
HP Laserjet 3005DN toner cartridge change
You don't. HP printers seem to be very particular about this.  Take it back and get the exact replacment, including the brand.
Jan 20, 2009 | HP LaserJet P3005n Printer
HP laserjet 1018. "toner can't be found"-an error msg from PC
hi,,
try to use a different kind of toner to fixed your problem.
rey
Nov 10, 2008 | HP LaserJet 1020 Printer
HP P4515n LaserJet Printer Logo
269 people viewed this question
Seeker5211
Seeker5211
