Question about Polaroid I533P Digital Camera
Inside lens of i533 polaroid
The inside lens is crooked, what can I do
  • 3 more comments
  • kbreh92 May 24, 2008
    Same problem, my camera lens is awkwardly stuck out.
    tried changing batteries. did work.
    please help! going to Amsterdam and really need camera! thanks
  • ambercarroll Jul 17, 2008
    my 3x optical zoom lens is stuck and i dont know what to do
  • lapachi Dec 16, 2008
    same problem...Polaroid 1533P apparently has a history of "stuck lens"
  • michelle6 Mar 06, 2009
    My camera lens is also stuck! I Have an i531.
  • hsadk Apr 03, 2009
    yeah same here and idk what to do so like yeahh it suckks.
Polaroid camera i533
well sure u just go to
Chandrakanth
+(91)-9346340947,9392416633
1-8-3/23/7 1st Floor, Hotel Sunanda, Chikkadpally, Hyderabad - 500020
Oct 24, 2008 | Polaroid I533P Digital Camera
My Polaroid i533 digicam won't turn on
Try checking to see if the lens is a little crocked, look at it real closley.If it is then try and pop, or bend the lens back into place, and then turn your camra on and the camra may work propelry.
I had the EXCACT smae problem, and it worked for me.
So it may hlep you too.
Aug 14, 2008 | Polaroid I533P Digital Camera
Polaroid i533
Check you camera instruction book. The card may be the wrong one or two large or???
Jul 26, 2008 | Polaroid I533P Digital Camera
Polaroid i533
Lens failure. There is no way to fix it.
Jul 24, 2008 | Canon PowerShot A520 Digital Camera
Is the polaroid i533 camera compatible with sdhc memory cards? Or does it only use sd memory cards?
No, the polaroid i533 camera is not compatible with sdhc memory cards. Use only SD cards.
Jun 27, 2008 | Cameras
Manual for my camera
Just type in i533 digital camera and it will show the manual.
May 23, 2008 | Polaroid PDC 5080 Digital Camera
Makes 3 beeping sounds then turns off
what happen if you put another memory card in it?
Dec 02, 2007 | Polaroid I533P Digital Camera
The lcd screen on my polaroid i533 digital camera went out
your screen is broken, some one must have accidentally put pressure on just the screen. The smae thing happened to my screen now i am looking to buy a new screen
Oct 27, 2007 | Polaroid I533P Digital Camera
Lens is broken
My daughter just had this problem with her camera. The camera was off with the lens barrel extended. When I looked at it closely, I noticed that the inner part of the lens barrel was at a slight angle to the camera. I pushed firmly on the low side of the inner part of the barrel, and it popped the rest of the way out. Camera works fine now. Good luck!
Oct 03, 2007 | Polaroid I533P Digital Camera
Polaroid I533P Digital Camera Logo
106 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
