Question about RCA P52926 52" Rear Projection Television
Sound quit can play dvd and viedo and play in surrond, but t.v. will not broadcast sound from t.v to surround.
  • fire120 May 21, 2008
    It was fixed by unplugging the unit and then plugging it back in.
    Champion:
  • 230 Answers
Adjust variable coil audio section. JUst turn a little bit and come back to same position. ( beside tuner)
Posted on May 14, 2008
Some of my speakers arn't playing sound on my HT-E555OW
If you are trying to play a cd, you must manually tell the unit to play it in surround sound. Cd audio defaults to stereo only. Does it do the same thing if you are playing a dvd? If it happens on dvd's as well, then something in the speaker setup menu is wrong.
Dec 25, 2012 | Shure Samsung Ht-E5550 3D Home Cinema...
I just got a blu-ray player and when I play some of the movies it will not come through the speakers. I have a surrond sound system that plays well on some movies and also plays the bonus features,but not...
DVDs have more than 1 sound track on them. That is to say different sound codings. You may well have to select the correct sound track on the dvd to suit your surround sound sysyem, this will be found in the options screen of the dvd (thestart menu).
Failing that, you may need to change the sound coding on your surround system to suit a particular film.
Jan 15, 2010 | Televison & Video
Proscan 37 inch LCD 37LB30Q Model
I used a swicher box form monster I plug in my viedo games and cable tv into it and then you run the composit cable which is high def into the tv but the sound into the swicher box the swicher box sound is run into the surround sound you just hit a button and you have the sound go to wall mart has the box for 20 dollars
Jul 08, 2009 | Proscan 19LB30QD 19 in. LCD HDTV/DVD Combo
Lg home theater to lg plasma tv
This is a typical problem with TV broadcast UNLESS you use a matrix DSP surround sound mode, most DVD audio is either Dolby digital 5.1 surround or DTS multi-channel surround sound, unless you are viewing a HDTV broadcast with 5.1 Digital sound connected from the TV to the receiver then you are probably receiving a 2 channel Stereo sound format, I would suggest that you try to set your TV input mode to a audio Dolby Pro- Logic which will yield 5.1 and should engage all speakers.
Feb 17, 2009 | LG LHT854 Theater System
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Component Video Connection
what you have done is you are sending a component video signal from your system to your tv and the sound i assume comes through the 5.1 surrond speakers. The DVD's you play the sound would naturally come from the 5.1 surround speakers, unless your instruct the dvd player to send the sound to the tv in which case will only be played as stereo. you will need inputs on your dav system to take sound from your tv outputs or digital box by way of red and white phono leads or a digital/optical input if you have them; so as to play the sound from cable tv or sattelite tv through your 5.1 surround speakers.
Sep 04, 2007 | Sony DAV-SC5 System
Problem with surround working with just the t.v. on
What type of plug from the TV are you hooking up to the sound system? Its has to be a HDMI or a scart. If its not and your using the rca red and white. The reciver has to be on the synth surrond setting or look in the owners manual, it will tell you what setting the reciver has to be on when using a non surround set or hookup
Sep 16, 2006 | Koss KS4102 System
RCA P52926 52" Rear Projection Television Logo
35 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
