When reinstalling my software for HPC7280 printer I received a messg that said "Fatal error, contact hp.com/support and MSI.net.deviceservicemamager40. Exactly what does this mean and what should I do?
  • 4,472 Answers
Here are two things that might work for you:
step 1>
remove netdevicemanager.msi from windows cleanup utility.
then try to install software again.
step 2>
remove netdevice manager from registry.
hklm > software > hewlett packard under hewlett packard you will find many {4dfg324.........} entries on left. if you will check each one of these code entries has its discription on right hand side of registry window. each one of these are for scan.msi, solution center.msi.... etc. fine out netdevicemanager.msi adn uninstall that {code} key from hewlett packard. these code keys may also be found in same location under hewlett packard under install key or installed options.
Then make sure to download and install the latest software/drivers from hp located here just select your OS in the first step:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&os=228&product=3204785
Posted on Aug 24, 2010
How to solve service error 49.00 in hp laserjet 2430dtn printer
49.XXXXX ERROR
A critical firmware error has occurred.
1. Press Cancel Job to clear the print job from the printer memory.
2. Turn the printer off, and then turn the printer on again.
3. Go to http: www.hp.com/support/lj2410, www.hp.com/support/lj2420, or
www.hp.com/support/lj2430. Click Download Drivers and Software. Check for the latest firmware image version at the bottom of the page. If this firmware image is newer than the
one installed on the printer and the printer can receive a firmware update,
download the newer firmware upgrade. Not all printer models can
receive firmware upgrades.
4. Try printing a job from a different software program. If the job prints, go
back to the first program and try printing a different file. If the message
appears only with a certain software program or print job, contact the
software vendor for assistance.
1. After performing the actions listed in the preceding item, if the message
persists when using different software programs and attempting specific print
jobs, disconnect all cables that connect the printer to the network or a
computer.
2. Turn the printer off.
3. Remove all memory DIMMs and thirdparty solutions from the printer.
4. Remove all of the EIO devices from the printer.
5. Turn the printer on.
6. If the error message disappears, reinstall each DIMM, Compact Flash card, and EIO device one at a time, making sure to turn the printer off and then on again (booting to the Ready
prompt) as you install each device. To replace a DIMM, see Appendix D - Printer memory and expansion in the LaserJet 2400 Series User Guide.
7. Replace the DIMM or EIO device that caused the error message.
8. Remember to reconnect all of the cables that connect the printer to the
network or computer.
9. If the error message persists, reinstall the firmware with the latest possible firmware upgrade. Go to http:www.hp.com/support/lj2410, www.hp.com/support/lj2420, or www.hp.com/support/lj2430. Click Download Drivers and Software.
Check for the latest firmware image version at the bottom of the page. If this firmware image is newer than the one installed on the printer and the printer can receive a firmware update,
download the newer firmware upgrade. Not all printer models can receive firmware upgrades.
10. Replace the formatter
Feb 28, 2011 | HP LaserJet 2430dtn Printer
Paper jam on hpc7280 printer noise from duplexer area NO PAPER JAM
Follow the instructions in this video. If you follow those instructions and still get the message, you may need to replace your printer or the rear door.
May 19, 2009 | HP Photosmart C7280 Printer
Fatal Error while install software for HP C8180 printer, Vistax64
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | HP Photosmart C8180 All-in-One InkJet...
HP f4185
well happy to help, i am sorry to say but the driver that ur using could be damaged and that is why u r getting error message. u could instal the driver from the site here is the link http://welcome.hp.com/country/us/en/support.html
Oct 24, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Fatal error installation of ProL7590
There are alot of fatal error messages. You need to provide the exact fatal error message.
Here are the basic troubleshooting for that type of error :
1. Turn off your firewall, anti-virus and spyware and then install it
if it will not work
2. Download the software for your printer in the website www.hp.com/support make sure that you are going to download and install the full feature of the software
Aug 03, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Fatal error installing HP 3055 all in one
Try download he right software for your OS from HP.com, typically software issue. Be sure to choose the right language for your full software solution, get fatal error when trying to install software with wrong language support.
Aug 02, 2008 | HP LaserJet 3050 All-In-One Printer
Hp officejet 6213 all in one problem
Unistall HP software and install a new set of software
At this link
Jul 18, 2008 | HP OfficeJet 6210 All-In-One InkJet...
123 people viewed this question
jasbo
jasbo
