Question about Nintendo Wii Console
Console not powering up. 110 verified to plug, but no light on console and it doesn't respond to reset, controllers etc..
  • 46 Answers
Get a new plug in
Posted on Aug 24, 2010
Red power light on but no picture
make this test and fix it. God bless you
  1. Verify TV is plugged-in and getting power.
  2. Verify your home's power breaker has not tripped.
  3. Verify the batteries in the remote control are good.
  4. Verify you have selected the right input for Cable/Satellite, antenna, DVD, VCR or Game Console.
  5. Verify the cable/satellite box is plugged in and getting power
  6. Verify you are getting cable/satellite in other parts of the house
  7. Verify the VCR is plugged-in,getting power, and turned on.
  8. Verify that all wires are connected to proper place
  9. Scroll through input screen to verify you are watching the correct inputs
Look at the FAQ on the manufacture's website or user manual
Use your remote control. The first step is to inspect the batteries of the remote control and see if they are functioning. If its power button starts to blink several times once you turned it on, then the batteries need to be replaced. See to it that your remote control is used within about 20 feet from the television. Make sure also that nothing blocks the space between the remote control and the receiver.
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
Jul 31, 2013 | Hitachi 57F710 TV
Printer not responding
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 27, 2012 | Lexmark X3650 Printer
F1 code means what?
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code F1
Apr 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Keeps beeping F1
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%#%
Apr 13, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
The f1 light keeos appearing
Feb 01, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Code F1
Jan 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error message
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$#@$#
Nov 27, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 code Whirlpool cabrio
Oct 19, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 Error Code On Whirlpool Cabrio
Jun 03, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Nintendo Wii Console Logo
26 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
