Question about Alessi Watches
I have a calumet watch, and the band is getting dirty. Is there a way to clean the band?
  • 831 Answers
Polyurethane Band
Polyurethane Bands, which are made of soft plastic, may turn hard after 2-3 year's use. Colour fading can also be seen.
If bands are kept wet and in highly humid locations or are exposed to sunlight for a long time, the deterioration of the bands may be accelerated in a relatively short period and some cracks may appear on the band surface. (This is called 'hydrolytic cleavage of polyurethane')
Kindly pay attention to the condition of polyurethane bands, which are often worn in such occasions as marine sports/outdoor activities
  • We recommend immediate exchange when your polyurethane band loses elasticity or develops cracks.
  • Semi-transparent/white/fair coloured polyurethane band may turn a different colour due to light/stain ( or sometimes may absorb colours from other materials). In addition, polyurethane bands have many small holes on the surface, which easily catch and hold stains/other different colour material. Thus it is rather tough to entirely clean polyurethane bands. Kindly replace current polyurethane band with a new one when you find extreme discolouration.
  • There exist some sorts of stains (like oil/cosmetics), which cannot be removed off. Smoking cigarette/long time use may turn the colour yellowish.
CAUTION!
Do not use solvent/chemicals (benzene/thinner/breach) for band/bracelet cleaning!
Posted on Aug 24, 2010
Cleaning
My universal cleaning solution is baby wipes, not sure if you've tried them but they are an inexpensive easy option
Mar 29, 2014 | Nixon The Decision Watch
Dirty white pierre cardin watch
Mild soap and very little water on a clean rag for the band. Scratches? on the crystal it means new crystal. On the case there may not be a solution depending on whether it is plated or solid metal(Stainless, gold, etc). If sold then it could be buffed. Doesn't sound as if it is a very practical watch.
Oct 06, 2012 | Watches
I want to change the watch strap, mine is brokem
Probably don't need special order band. Most people buy band that is same width. Bands have a collapsible post on each side where they attach to the watch, you just pick a band that fits the width. To change a watch band you have to use something like a razor blade (single edge common to cleaning) to wedge between the metal frame of the watch and the band, then try to get some friction on the post and push it away from the watch and toward the middle of band such that you collapse the post and get it out of one hole that the post is in (2 holes 1 on each side of post) so you can tilt the post out. A new band usually has 2 posts included since it is common to bend the old posts getting them out and hard to just buy those. Put the post in the band, put one end of post into a hole, then tilt and compress with the razor to push post into position, then slide the razor out which allows it to go in the second hole. Now band stays attached.
Jan 10, 2012 | Adidas Adistar ADP1786 WW Watch for Men
How do you replace or clean the white leather part of the watch band? The leather has gotten dirty and I have tried tennis shoe cleaner and Mr. Clean sponge wipes.
mcdevito75 here, I don"t think there"s too much more you can try as I have had the same problem, Best Bet, replace the strap.
Jun 21, 2010 | Ecclissi J45450 Wrist Watch
Watch lost 10mins daily then stoped . bought in jamaica in september 09, took watch to get new battery, jewler said battery was fine ,tried new one watch did not function. said mecanism not working
Probably the mechanism is dirty or gummy. If I had it I would try some special spray that helps to clean the gears. Then I would use an instrument that pulses the movement and gets in moving again. Maybe someone could do that for you. Generaly, if that doesn't work then ii is cheaper to just replace the movement rather than spend more money on the labor to try and revive your old movement, Lots of luck
Nov 05, 2009 | Kenneth Cole Multifunction Black & Silver...
Fossil ladies 2-tone watch with blue dial
vinegar and bicarbinate of soda will work perfectly
Aug 15, 2009 | Watches
Discolored white nautica watch band
If your watch band have UV sensitive pigmentation in it, there is nothing you can do, but buy the new band.
Find your nearest jeweller and ask to clean watch band in ultrasonic cleaner for 1 hour. If this kind of cleaning doesn't help, that means your watch band is UV sensitive and is and will be discolouring more and more by the time.
Alternatively you can try to clean it with the lighter fluid (ZIPPO). Soak a soft cloth in to lighter fluid and clean the band. Start with a small area inside band to make sure the fluid is not reacting as dissolver, as some resins react quite vigorously and tend to transform into chewing gum sort of state.
And again- if this cleaning doesn't help, the band is UV sensitive and discolouring is taking place.
That discolouring is happening becouse some of the colour pigments used in resin manufacture are sensitive to ultraviolet light and when exposed to sunlight or daylight, they react in a chemical
way, changing molecular structure, wich we see as the colour change.This process can not be reversed and this is why the band can not be cleaned.
Do not forget to rate please.
Jan 25, 2009 | Nautica N07574 Wrist Watch
Ironman Triathlon Sleek Ladies watch Band problem.
try simple free or a citrus solution often found in household cleaners. js
May 24, 2008 | Watches
Watches Logo
456 people viewed this question
Top Alessi Watches Experts
Ansel Alberto
Ansel Alberto
Are you an Alessi Watch Expert? Answer questions, earn points and help others
