Question about HP Office Equipment & Supplies
Hp2055dn won't print. It shows it is "Ready", but print files just sit. This happened once before, about two weeks ago, but it worked itself out. This is a new printer, only a month or two old.
checkitright
  • 1362 Answers
SOURCE: hp laserjet 4 plus printer, message window "Ready", off line button shows red
You can try to do a "Cold reset"
turn off the printer hold down  the Menu/reset button and turn it back on.
Do you hear the machine go into rotation? the 4 plus has a high pitch sound follwed by the fuser turning ( you'll know when it does it) if it doesn't go into rotation then there is another problem.
Posted on Oct 15, 2007
  • 105 Answers
SOURCE: HL-4040CN don't show or read new refilled magenta cartridge.
If you have removed and reinstalled the magenta cartridge several times, it is very likely the cartridge is defective out of the box. If you have another magenta cartridge, put that one in and see if the problem resolves. I'm betting it will. If that second cartridge does work, then return the defective cartridge to where you purchased it - they should replace it without a hassle.
Posted on May 13, 2008
adonscott
  • 106 Answers
SOURCE: Cannot print with wirelessly networked printer
hi,
if printing from 2 other computer works fine, will i think its not an issue of IP address which changes somehow. but anyways, try to check if you still have other printer drivers under "PRINTERS" (see control panel). it should say HP Photosmart c6100 series. If you also have there a printer icon that says HP Photosmart c6100 series Copy1, try using it (right click on that icon and choose Set as Default Printer). If you only have HP Photosmart c6100 series under PRINTERS, try to right click, then choose properties. When Properties box is open, click on PORTS tab. then click on configure ports below. Try to type in the IP address of the printer under "Printer Name or Host name or IP address". make sure that you already printed network configuration page to get the exact ip address of the printer, Dont know how to print? do this.
PRINTING NETWORK CONFIGURATION PAGE
1. press setup, then scroll down and look for Network.
2. press okay on network, it will give you the first option "VIew network settings".
3. press okay on it, and it will give you the first option "Print network configuration page."
4. choose that and press okay. it will print the network config page. from this document, you will be able to see the IP address of the printer.
Please let me know if the issue is still not resolve so that i can go ahead and give you another possible solution.
Thank you so much.
adonscott
Posted on Jul 07, 2008
SOURCE: bought it a month ago printer status says ready but jump to file willnot print
You need to ensure your document isn't set to print to a windows document printer. Change it to your defaut printer and it'll work.
rstrg2
Posted on Sep 04, 2008
SOURCE: Brother HL-4040CN won't read or show new refilled cartridge in the LCD
I think I know what the problem is...
When you refill these toner cartridges you need to reset the "toner empty" cog wheel.
For instructions on how to do this follw this link:
http://www.proprint.co.uk/brother_hl4040.htm
It has pictures and explains how to reset the cartridge
Good luck,
Billy.
Posted on May 13, 2009
Jetta key won t unlock door
It's the key. Go back to the mechanic and ask them to have a locksmith fix the issue at their cost.
Feb 08, 2014 | Cars & Trucks
Riso Rp3700 won't print from computer
We suffer the same issue. Have you find the solution?
May 02, 2013 | Office Equipment & Supplies
My cell phone was put into the washer a couple of moths ago?
Once they get wet and sit for a long time, it's not usually worth the time and money to repair them. It's a miracle that it still works at all with that amount of submersion. Good luck!
Mar 12, 2010 | Samsung SYNC SGH-A707 Cellular Phone
Htc touch elfin keeps switching off by itself
I am also facing the same problem and I purchase this around 2.5 yrs back. Now the situation is very pathetic, it switching off very frequently for every 1 hr. please let me know the solution. if any one has
Oct 21, 2009 | HTC Touch P3450 Smartphone
DLINK DP-300U. Desktop shows printer offline, Laptop prints OK.
First thing.. plug printer directly into PC.. does it work? .. if so its is a port setting. If now it is the device config on PC
If Port Setting Issues.. are you going through any other devices on the network or is you firewall blocking the IP.
If device Config issue check to see it is setup up as an IP Port not a normal local port
Jul 15, 2009 | D-Link DP 300U (DP-300U) Print Server
Jensen VM9410 - Stopped Operating All Of A Sudden
Sound like to me you got a problem with the capcitor inside the unit, if its under warrenty it will need to be serviced. If its not I ould be checking capcitors inside to make sure there not bulging leaking or otherwisen ot wroking correctly.
Jun 24, 2009 | Jensen VM9410 Car DVD Player
Bought it a month ago printer status says ready but jump to file willnot print
rstrg2
Aug 23, 2008 | Dell Photo 964 All-In-One InkJet Printer
Polaroid FLM-3232
Unfortunately, LCD panel has cause of the problem and it's not worth to fix.
Sep 16, 2007 | Polaroid FLM-3232 Television
176 people viewed this question
Seeker5211
Seeker5211
