Question about Intec Pro Gamer's Case for Playstation 3
What combanation is pre set when case is new - Intec Pro Gamer's Case for Playstation 3
What is the setting for the gap
Pretty sure that Car uses iridium plugs if this is the case you do not ever gap those plugs they come pre gapped.
Mar 05, 2016 | Toyota Cars & Trucks
Pre out for Sub woofer on AVR 1601 not working
Is this a new problem, as in it worked before? If it's a new hookup, it's possible the sub you have isn't powered. In which case, it won't work. PRE out is 'preamp' for powered subs.
Dec 27, 2013 | Denon AVR-1601 Receiver
Need a setting for Scott's Speedy Green EdgeGuard mini
First, I went to the products website, in this case Lesco and looked up the spreader settings:
https://www.johndeerelandscapes.com/home/spreader-settings.aspx
Then, I went to Scotts website and looked up spreader settings:
http://www.scotts.com/smg/node2/SCOTTSCOM/lawn-care/lookup-spreader-settings/7800015-24900013-s
I cross referenced a product on the Scotts website that uses the same settings as one of those listed on the Lesco website and I found my settings that way.
In my case I was using Lesco Pre-M 0.86% 0-0-7 and wanted to apply 5.3 lbs/1000ft. My spreader was a Scotts Turf Builder EdgeGuard Mini with settings from 0-15. I found out by cross referencing that the Scotts Speedy Green 1000 and my spreader used the same settings. So I ended up using the recommended setting of 5.5, as listed on the Lesco website for the Scotts Speedy Green 1000, to apply 5.3 lbs/1000ft of pre emergent using my Scotts EdgeGuard Mini.
Hope this helps!
Mar 30, 2013 | Scotts Company Garden
Want to change combanation number
a1 locksmith burlingame has posted reprogram new user code instructions bottom of this page.
Mar 21, 2013 | Sentry Fireproof Safe
Spark Plug Gap for 1996 GMC Jimmy
They should be pre-gapped, but you should always check in case someone dropped the box.
The gap is .060
Jul 18, 2012 | 1996 GMC Jimmy
I have a somesonite 30in hardshell , uprite about 20 yrs old. has 2 key locks, as well as combanation center lock. question how can i set these locks so that, they are TSA excessable locks??? PLS. Help ...
You can have the locks changed but, that will cost almost as much as new luggage. They will have to be kept unlocked and a TSA strap will be needed around the suitcase.
Oct 07, 2010 | Samsonite Silhouette 11 Hardside Spinner
Yeah my ipod screen is locked i cant rember my four digidt comban
try restoring the ipod to its original settings when it is plugged into your computer.
Dec 31, 2009 | Apple iPod nano 3rd Generation
3 PANASONIC TVS HOOKED UP TO CABLE SYSTEM AND ARE ON 37" PANASONIC TH-37PX50U WORKS FINE BUT THE OTHER 2 TVS DO NOT WORK. THE CABLE SYSTEM HAS BEEN CHECKED TWICE AND WE ARE TOLD IT IS OK BY TIME WARNER...
unhook 1 tv at a time leaving 2 tvs each time hooked up. try every combanation Possable to see if it's a tv problem or if when you have all 3 tvs hooked it makes the signal weak. this can happen cable guys say no but it can been there done that. if 2 works and 1 dont in every combanation the problem is in the cable system. most cable guys check the signal outside. with the splitter block unhooked. this gives a false reading.
Oct 31, 2009 | Panasonic TH-37PX50U 37 in. HD-Ready...
Pre-Set Timer program not recording
Just a hunch, but did you check the clock settings after the time change?
Nov 08, 2008 | Samsung DVD-V3650 DVD Player/VCR
Intec Pro Gamer's Case  for Playstation 3 Logo
Top Intec Video Game Consoles & Games Experts
Martin Murray
David
David
Colin Stickland
Colin Stickland
Are you an Intec Video Game Console and Game Expert? Answer questions, earn points and help others
