Question about Kenmore Washing Machines
Older Kenmore model 110.82673110 washing machine keeps tripping the GFI. Replaced GFI but problem persists. How can I fix this?
  • 139 Answers
I would install a regular outlet... and if the circuit breaker blows. then their is a direct short within the washer .i never heard of GFI being used on a washer ..remove it.. their may be other outlets on this circuit also that can adding to it tripping. like frig.. find out what is on that circuit by shutting off the breaker for washer see what else goes off...
Posted on Aug 24, 2010
How to fix whirlpool gas dryer . keeps tripping GFI washer on the same circuit does not trip the GFI
sorry that a bit confusing u said it trip the gfi then u said it does not trip the gfi?
Jun 14, 2015 | Whirlpool Washing Machines
My washer keeps tricking my electric wall switches of it is so annoying can anyone suggest why this happens
I guess you are referring to a GFI outlet. They are supposed to trip on leakage of voltage (which happens on all machines with motors). GFI weaken over time so my first and cheapest fix would be to replace the GFI. If the GFI is not the issue, this problem becomes much bigger and compicated.
Oct 20, 2014 | Washing Machines
GFI breaker tripping
It could be a faulty pump,
rusty pump & moisture on copper windings leaks active, neutral back to earth on your pump & trips your breaker.
Solution: Replace pump.
Aug 21, 2013 | Fisher and Paykel Washing Machines
Gfi outlet trips right before the final spin cycle. This is on a top load kenmore 80 series washer. I replaced the timer but the problem still exists. The timer seems to be in a pause mode. In other words,...
Motor driven appliances can trip GFI outlets when there is no problem at all with the appliance. When a large motor first starts, it draws more current for a short time and some GFI outlets will trip (others may not).
Are GFI outlets required by code in your state/county for washing machines? If not, replace the GFI with a standard outlet. If so, replace GFI with a higher quality GFI outlet.
Nov 30, 2012 | Washing Machines
Frig is intermittently tripping GFI outlet.
To be short, the only thing in the machine that really has the capability of causing that is the compressor. Its got a floating short in and when it makes contact it trips the outlet/breaker. Check for any exposed wires just to be sure but I'm pretty certain that the compressor is the culprit and either it or the machine needs to be replaced.
Apr 21, 2012 | Kenmore Refrigerators
Kenmore 417.40412700 triping GFI receptacle
Amperage pull too high. Increase the rating of the GFCI outlet - or there i an issue with the washer itself.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 19, 2009 | Washing Machines
Kenmore 417.40412700 tripping GFI circuit breaker
Unfortunatly washing machines are too sensitive for GFI outlet.only way to fix is too take it off the GFI.
Mar 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
LG washing machine trips GFI Circuit Breaker
WASHING MACHINES ARE NOT TO BE CONNECTED TO GFI OUTLETS AND TRY TO CONNECT IT TO A CERCIUT THAT IS NOT WITH YOUR DRYER. (REG) OUTLET.
Jan 02, 2009 | LG WM2016C
Trips GFCI receptacle for laundry circuit.
I ran into this problem with a washer this summer. the gfi breaker needs to be replaced. it is weak and trips easily. if you can run an extension cord to an outlet without the gfi andrun your washer, you probably will not have any issues. that is what I found with the washer this summer. when it was plugged into the gfi, itwould trip. but when I had it plugged into a regular outlet, it was fine. Joe
Nov 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 80 - in mid spin cycle the machine tripped GFI
check your pump ,,, sounds like you gotten something in it putting a strain on the motor to overload your breaker
Nov 17, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
226 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
