Question about GE GSS20IEM Side by Side Refrigerator
Ge GSS22KGMD not cold at the top of freezer or making ice. Bottom of freezer is cold
  • GE Master
  • 1,606 Answers
Jharper is correct....the fan in the freezer must not be working . Replace the main control board..pt # WR55X10942 , as this supplys the dc voltage to the fan motor .
Posted on Aug 24, 2010
  • 139 Answers
Is the fan motor on in the freezer ?is the coil frooze up?
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Ice maker has water but no ice
HI.TERRY.freezer has to work at its optimum.for the ice maker to work. i would try to defrost the freezer completely first and try.good luck.Ali
Jun 28, 2012 | Samsung Refrigerator Ice Maker -...
GE 17.2 freezer on top fridge on bottom. Freezer is cold, but fridge is warm. Help!
Is there any frost buildup on the rear panel inside the freezer? If so you have a defrost problem of a bad defrost heater, defrost thermostat, or defrost timer/ control board. If no frost then you probably have a clogged defrost drain. Remove the rear panel to access drain hole.
Nov 09, 2011 | GE 17.2 Cu. Ft. Top-Freezer Refrigerator
I just got a G E refrigerator from home depot model # gbscohcxarww. And the freeZer on the bottom works but the ref rig on top doesn't get cold
set dials to middle setting, max cold makes cold freezer, not reefer box!! if freezer makes ice its ok just set to cold which starves reefer box of air. add 2-3 gallons of water to the freezer and or reefer box, if empty it wont cool much.
Nov 01, 2010 | GE Refrigerators
I have a GE refrigerator model# GSS22KGMD that keeps freezing the water coil inside behind the crisper. What is the solution to this?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Nov 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
GE Refrigerator cooling system problem
My guess is that you need more refrigerant gas. It may also have a problem with the auto defrost system for the freezer. You have a block of ice in the evaporator instead of clear fins for the air to pass through. Make sure the door is correctly closed and that the magnetic door gaskets are in good condition. Once those are fixed you can turn the thermostat to make the fridge a bit warmer. Another possibility is that the circulation fan in the fridge has failed. Cold air falls to the bottom which is why your veg is freezing. You can't work on refrigeration gas yourself anyway, so call an engineer. Correct diagnosis of the fault will be cheaper.
Google
'<your city> GE refrigeration service'.
Dec 06, 2017 | Pds GE Profile Bottom-Freezer Drawer...
GE Side By Side top portion of fridge and freezer not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Fridge wont stay cold in the bottom.
Your frost free is not defrosting properly. There should be no ice buildup in the freezer section. Frost in the freezer section stops air circulation to the refrigerator section.
Jun 28, 2008 | GE Refrigerators
GE GSS20IEM Side by Side Refrigerator Logo
252 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
