Question about Kenmore 82836 Gas Dryer
Kenmore front loader HE2
Runs for a few min then stops and starts flashing F22 with all lights flashing too
  • 460 Answers
F22 Error means
after 6 failed attemts to lock the door.
Possible Causes/ Procedure 1.-*Door lock mechanism is broken or removed from door. 2.-Door  switch/ lock unit failure. Check door switch/ tock unit. 3.- Check the wire harness connection to the door switch / lock unit and Central Control Unit (CCU).
was this helpful?
Posted on May 14, 2009
My HE2 front loader dryer flashes f22 and stops. A repair man has replaced the thermistor twice, but it is still flashing the same error.
This means the outlet thermistor, the one on the blower housing, is open. But since the thermistor has been replaced twice and the error code still flashes (make sure it is cleared after the replacement by pressing STOP twice), the wire harness (including the connectors) connecting it to the electronic control board is cut open or the electronic control board itself is faulty and not detecting the thermistor connected.
Check the connections and the continuity of the wire harness and replace or repair it if found cut open. Consider a faulty electronic control board if the wire harness and the connectors are intact and the thermistor is known to be 100% good. Normal thermistor resistance is around 8500 ohms to 13500 ohms at room temperature (27-21 degrees centigrade).
Mar 09, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore HE2 flashing lights
did the technician point out wat needs to be repaired
Aug 24, 2008 | Kenmore 46462 Front Load Washer
Sears kenmore he2 front load pump filter maintenance
Kenmore HE2 front loader. We had a problem with all the cycle lights blinking. I took that access cover off and found 4 years of lint and muck with a few fabric items in that sump. There is also a second troubleshooting manual taped to the back of the access door. after cleaning the pump filter it worked fine. This should be in the owners manual but its not, they say to call the service guy and be charged an arm and a leg
on May 09, 2010 | Washing Machines
Cylce stops after 1st drain before spin out
I have kenmore washer front load H2 after 1st circle of wash it stop and start beeping with code F11. My email address is anarfi1212@
Jan 21, 2010 | Kenmore HE2 Plus Front Load Washer
Error codes
Kenmre HE2 Plus front loader has a F 28 error. Whats the problem and how do I fix it?
Jan 19, 2010 | Kenmore HE2 Plus Front Load Washer
I have a he2 kenmore front end loader washing stops mid load and flashes F20
Something is in your pump trap, easy fix. pop open the bottom panel by removing the three screws under it. requires a torx bit or a nut driver. if you can tilt the washer back so the front legs are a foot or 2 off the ground, it will make this a lot easier. once open you will see a twist off cap. before you remove this be prepared for the residual water to eject out when you open it. these can not get all the water out so there is always some, tilting it back will minimise this or putting hose clamps on the pump to tub hose can help but not nesesarry. twist it out and clean it out, also stick your fing into the two holes where the trap is located to see if any coins have gotten stuck. once clean, make sure you line up the trap arrow with the base. then button it back up, good luck
Dec 04, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Washer knocks very loud on spin cycle and a belt or something has been coming out in pieces for the last few weeks
I just took the back off my older kenmore front loader and discovered that the concrete counter weight had come off the drum and fallen to the bottom of the machine. Reattached it and knocking has stopped, lucky it didn't trash the machine as it is normally attached to the top of the drum.
Oct 13, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore dryer HE2
my kenmore he2 gas dryer runs for 2 or 3 minutes the shuts off, flashing an f22 error code
May 05, 2008 | Kenmore 85871 Electric Dryer
Kenmore 82836 Gas Dryer Logo
259 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
