Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Not cold, Fan is running and lights are on - Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
  • Kenmore Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 24, 2010
My air is not all that cold and when I am stop at a red light it blows warm air it has plenty of Freon in it. What could it be?
If the air is cold when the vehicle is moving and goes warm when stopped,the fan at the rad/condenser may not be working,or working but not running fast enough.Sometimes there may be a second fan that comes on also.If the fan/fans are running and you can get cold air at a stop by increasing rpm then the system may be low on refrigerant.
Jul 09, 2017 | Cars & Trucks
Side by side GE turbo-cool Gss25XSRBSS, the freezer seems to be fine, the fridge is not cooling. Fans seem to be running smoothly, no weird noises. Turbo cool turns on. It hasn't been running for
if you go here you can see the damper,fan assy. that's in the top of your machine in the fresh food side
http://www.repairclinic.com/PartDetail/Damper/WR49X10091/1055112
this is a damper with another fan in it,when the t-stat calls for cold air the damper door opens to let the cold air in from the freezer and the fan in it blows the cold air around inside the fridge,if the freezer is fine and the fridge side is warm most likely this is your problem,part number WR49X10091 and it's around 130 dollars.unplug the machine,remove the light cover on the ceiling,remove the 1/4 inch screws and drop the light assy.remove thhe filter cover on the right side so you can remove the damper assy.pop off the cover on the piece that runs up the back center,remove the screws to the damper,read the instructions and put it back together again.should take you around 45 to 60 minutes.hope this helps and good luck.
Sep 27, 2012 | GE Refrigerators
Larder fridge light on but not getting cold
Check condenser clean and warm. If too hot, may be fan not running, if too cool, compressor not pumping or short of gas
Aug 07, 2012 | Frigidaire Refrigerators
FRIDGE LIGHTS ON, FAN MOTOR RUNNING. NO COLD
you need a new RTX contactor on the compressor body,the compressor isn't operating
Dec 24, 2009 | Refrigerators
The lights are on in the refrigerator and freezer, but neither unit is cold. The thermometer on the refrigerator registers 55 degrees. Why is it not cooling??
First, make sure the compressor is running. It is underneath the refrigerator body. If the compressor is running, and you still don't have cold air, check the compressor fan. This should be close to the compressor. This fan draws air across the coils and removes heat from them. The compressor and fan must both be operating properly to get cold air.
Oct 18, 2009 | Refrigerators
My u-line 75rfb-00 refrigerator wont get cold the light comes on the motor sounds as if its working but it only gets cool not cold ?
Then you need to see if the compressor is running or is it the fan? You migh be hearing the compressor come on for a short while. The fan might not be running. Replace the fan if its not running
Sep 26, 2009 | U-Line 75R Refrigerator
Beverage air model UR30G, not cold, fan still running
check the thermostat for proper setting, evap could be frozen up, the condenser fan could not be running, unit could be low on freon. start check some items and let me know.
Jun 09, 2009 | Carrier Beverage-Air UR30GEFD Beverage...
The unit is nolonger cold and ice is melting
i have the same problem as above. the lights are on in both the refrigarator and freezer. I do hear the motor (fan) running but there is nothing cooling coming out.
Feb 15, 2008 | Whirlpool ED5GTNXMQ Side by Side...
Fridge doesn't get cold enough
 If the evaporator fan is not running. The fan itself could be faulty or the door operated light/fan switch could be faulty.
If the evaporator fan is running. The fridge is not defrosting and ice has built up on the evaporator and the air is not circulating properly into the fridge compartment. The fan circulates cold air into the fridge and back through the fridge control which is normally just an adjustable flap which allows more or less cold into the fridge depending on the setting. If the fridge is not defrosting, the defrost timer could be faulty or heater element could be blown.
Nov 03, 2007 | Roper RT12VKX Top Freezer Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
29 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
