Question about Durabrand PDV-705 Portable DVD Player
Mi reproductor dvd pdv 705 no enciende y la luz piloto solo enciende en amarillo continuo, quer puede ser???? gracias
5 Suggested Answers
SOURCE: dvd
ribbon cable issue found with this device. look inside at the white ribbon cable. The cable likes to bunch in bewtween the spinning hub and the eye assembly, after time it may even develope a rub spot that will shut you down for good. If the cable is bunched up, try pushing it back into the bottom of the device and try again.
Posted on Jul 11, 2008
  • 303 Answers
SOURCE: looking for power adaptor for durabrand pdv-705
click on hyperlink
buy replacement ac power adapter Durabrand PDV-705 PDV705
Posted on Feb 12, 2009
  • 303 Answers
SOURCE: I need to order a whole set of new cables
click on hyperlink:
buy replacement ac power charger adapter Durabrand pdv-705
Posted on Jun 01, 2009
style_points
  • 34 Answers
SOURCE: DVD says loading.... but keeps turning, stops, turns, stops
It is a problem with the laser. Getting a lens cleaner could help, but it is doubtful. Your best bet, tap the unit while the disk is trying to load.
There is a motor that moves the laser into place. Often the motor burns out or it does not focus correctly after a while. Sometimes, they just get stuck. A tap may kick start the motor into place if it is stuck. Most likely, you will have to replace the unit.
P.S. Toothpaste and electronics don't mix. CD players get extremely hot. You will eventually be cleaning Crest out of your DVD player.
Posted on Jul 25, 2009
Jeep liberty 2004 se enciende una luz en el lado derecho del tablero de color naranja q es
Exactamente cual es la luz que ve en su tablero...
Comentenos para poder darle mayires detalles.
Nov 24, 2011 | 2004 Jeep Liberty
Hola mi lectora no lee los CD?,
Haga clic en iniciar el control de las herramientas administrive panel, administraci?n de equipos, administrador de dispositivos, despl?cese hacia abajo cd-dvd rom unidades puede ver un signo de interrogaci?n amarillo? bot?n derecho del rat?n tendr? opciones para actualizaci?n del controlador, Volver al controlador anterior o seleccione las propiedades generales de solucionar problemas, seleccione el controlador, haga clic para volver a instalar los controladores de clic en Actualizar controlador o desinstalar y reinstalar, si esto no soluciona el problema puede ser que sea un problema del registro si no puede ver su unidad de disco en el Explorador de Windows
Cierre todos los programas
Haga clic en Inicio, Ejecutar y escriba regedit y oprima
Haga clic en el signo m?s (+) junto a las carpetas siguientes
HKEY_LOCAL_MACHINE
SISTEMA
CurrentControlSet
control
clase
{4D36E965-E325-11CE-BFC1-08002BE10318}
Esta carpeta es el reproductor de DVD / CD-ROM Descripci?n de unidad de clase en el registro. Busque cualquiera de los siguientes nombres en la columna de la derecha.
Filtros de alta
Filtros de baja
superior Filters.bak
menor Filters.bak
Si alguna de las teclas de arriba se muestra en el paso 4 en la lista, haga clic derecho sobre ellos y elija Eliminar Despu?s de eliminar las teclas, cierre el editor del registro
Reinicie su computadora
Abra Mi PC y compruebe si su unidad de CD o DVD han regresado. Tambi?n es posible que desee abrir el Administrador de dispositivos y verifique que el signo de exclamaci?n amarillo y el c?digo de error en la unidad de CD o DVD se ha ido. o
puede que tenga que desconectar f?sicamente los cables de este cd / dvd luego enchufe de nuevo este debe activar el Asistente para hardware nuevo o
puede que tenga que desinstalar y reiniciar el equipo vuelva a instalar el reproductor de DVD / CD vuelva a instalar el controlador de este dispositivo
Si el equipo viene con un disco de la placa base los controladores podr?an estar en ella
haga clic en Inicio, Panel de control de las herramientas inform?ticas de gesti?n administrive administrador de dispositivos, despl?cese hacia abajo cd discos DVD-ROM si usted ve una cuesti?n de color amarillo o signo de exclamaci?n? ! o una X roja, haga clic derecho tendr? que actualizar el controlador o
Sep 09, 2011 | LG CRD 8521B Internal 52x CD-ROM Drive
Tengo un lg42lh55 que enciende la luz en azul y a los 2 minutos pasa a rojo, solo tiene un mes de uso que puede ser?
Puede ser su planta de luz dentro de telvisor esta danado, endonsis usted tiene dos opciones
1. Reparacion con un technico
2. Reparacion con partes www.partstore.com tiene un planta nuevo.
Por Favor deje un voto positive por su repuesta gratuita.
Gracias.
Saludos
Rulds2008
Aug 23, 2011 | LG 42LH55 42 in. HDTV LCD TV
He desconectado la vateria y el reproductor eclipse ucnv884 se desconfiguro, solo aparece abrir CD, DVD necesito urgentemente ayuda, escribir a trebmil@hotmail.com. Muchas gracias
Estimado, a mi me paso lo mismo que a ti con mi reproductor Eclipse, me puedes decir como lo solucionaste?
mi correo es ppereira@transantartic.com
May 10, 2011 | Eclipse (AVN7000) Car DVD Player
Mi USB ya no funciona no puedo escuchar musica en el solo se sirve como U que debo hacerSB no como MP3 no reproduce mi musica
Puede ser que el reproductor solo este bloqueado por la tecla deslizable HOLD, habria que probrar deslizando la tecla en sentido contrario al simbolo HOLD > .
Feb 21, 2011 | Coby MP550 MP3 Player
No enciende solo tira una luz anaranjada atras de la carga
Hola:
1.- Desmonta la bateria (por debajo de la Laptop tiene, generalmente dos seguros, tira hacia afuera y se soltará la pila).
2.- Desconecta el cable de alimentación de la Laptop (eliminador).
3.- Intenta encenderla, dejando presionado el botón de encendido durante 15 - 30 segundos.
4.- Conecta solamente el cable de alimentación (sin bateria).
5.- Presiona el boton de encendido en forma normal.
Estos pasos sirven para descargar todo el circuito electrónico del equipo y/o desbloquearlo por alguna posible sobre carga eléctrica. Ve si funciona.
Si no enciende, intenta lo siguiente:
1.- Desconecta el cable de alimentación y batería.
2.- En la parte de abajo de la laptop, localiza una tapa con un ícono identificador tipo chip; desmóntala liberando el ó los tornillos.
3.- Retira el ó los módulos de memoria, jalando los seguros laterales de cada memoria. Tómala por los bordes.
4.- Limpiar o lijar los pines (contactos) de la memoria. Puedes usar un borrador de lápiz o una brocha impia y pequeña.
5.- Instalar un solo módulo de memoria, si fuera el caso.
6.- Encender la laptop sólo con el cable de alimentación.
Este procedimiento corrige una posible falla de lectura en la memoria que impide realizar el POST del equipo correctamente. Ve si funciona.
Espero y ayude. Gracias
Jan 31, 2011 | Acer Aspire 3680 Laptop
No enciende solo para traspasar informacion
Hola, este es traducida por Google Translate cliente.
Si actualiza el reproductor de medios digitales y sólo alcanzó el 60% en la actualización, el software (programa) piezas II y tiene que actualizar de nuevo.
Si no, puede tratar de explicar en otras palabras, de nuevo aquí.
Buena dias
lfete da DK
Mar 17, 2010 | Philips GoGear ViBE Digital Media Player
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
Problemas de transmision automatica
hola que tal, tengo un saab 9000 1988 y tengo problemas con la transmicion aveses me hace los cambios y abeses no, si abansa para atras y para adelante pero me abienta los cambios cada que quiere,,, alguin tiene idea de que pueda ser?? nesesito ayuda ya estoy desesperado...
Aug 02, 2009 | 2001 Hyundai Accent
Durabrand PDV-705 Portable DVD Player Logo
56 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
