Question about LG LRSC-26922 Side by Side Refrigerator
I have an LG LSC26905TT side by side fridge
Recently our water started getting weaker and weaker and finally stopped altogethe out of the front dispenser. I checked the water filter and the water inside it was frozen solid. I then thawed the block of ice and placed the water filter back in. When i push the door lever to dispense water the water inside the fridge sprays, like there isn't a proper seal. Thinking maybe a line was frozen, i unplugged the fridge for an hour and tried again with the same results. Any help please
  • 489 Answers
When the filter freezes up, the outside casing may have cracked and will leak water when you dispense water through the door.  You will need to have the filter replaced and that should take care of the problem.  But the filter should never have frozen in the 1st place.  You will need to call a qualified LG technician to see what's going on inside the refrigerator.
Posted on May 11, 2008
LG side by side model# lsc26905tt, won't dispense water. I can hear the pump trying to pull water but the water is sitting in water line just outside of filter on the outside of fridge.
Sounds like the dual solenoid water control vave. Located in the back it will have two wire connectors going to solenoids. They are replaced as a pair and most local appliance dealers have universal replacemants. http://www.lg.com/us/refrigerators/lg-LSC26905TT-side-by-side-refrigerator
May 31, 2015 | LG Refrigerators
Lg sxs fridge not getting cold
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 16, 2010 | LG LSC26905TT Side by Side Refrigerator
Our LG fridge had an issue where the water supply was cut off, so the ice cube maker stopped working as well as the water dispenser in the front. The water valve was replaced, and the ice maker started...
it could be a frozen water tank inside freezer door. if so, door will need to be replaced; as, there was maybe a spot where the foam inside door wasn't sprayed properly. disconnect water line fitting under door behind kick plate; close door and try dispenser. this will verify if it's the door or not.
Sep 22, 2010 | LG LSC26905TT Side by Side Refrigerator
My side by side is not making ice anymore?
Tania, if your unit is only 5 weeks old you should call an LG service co to repair in warranty. you shouldnt have I/M problems this early
Jan 21, 2009 | LG LSC26905TT Side by Side Refrigerator
Ice maker panel came loose on LG LSC26905TT fridge
Please use the attched link to get the service and user manuals for your fridge. There are exploded views there as well so that should provide you suffiicient information to reinstall your panel. You can also get part numbers etc for replacements if that is necessary.. Hope this helps you...
http://136.166.4.200/contents/Fridge/LSC26905.htm
Regards,
Rick
Nov 27, 2008 | LG LSC26905TT Side by Side Refrigerator
Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Sep 19, 2008 | LG LSC26905TT Side by Side Refrigerator
Water filter replacement
Fm, it's not threaded, turn it counter clockwise until it stops (should hear a click), then pull it out. Push the new one in all the way and turn it clockwise, you should hear it snap in. You may have to use a little force. If you are still having trouble, give them a call at 1-877-714-7481. Catriver.
Jun 28, 2007 | LG LSC26905TT Side by Side Refrigerator
Another Ice Maker Problem
i suspect that repair man got it wrong. ice may be blocking return duct to fridge. worth a chance to turn off for 24 hours with doors open then retry
Jun 14, 2007 | LG LSC26905TT Side by Side Refrigerator
LG LRSC-26922 Side by Side Refrigerator Logo
721 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
