Question about HP JBL Platinum Computer Speakers
How do I hook them up. Moved and can't remember how to hook them up. I have them on the side of the computer with plug in , one on the left side and 2 plugs on the right side...no sound
  • 104 Answers
Speaker A should two cables running from it plug one end into speaker B a large RCA jack,
Plug the other end into your PC Sound card (speaker out ((( )
then if it's a active systems plug Power converter into A/C port on back of Speaker A
Posted on Aug 24, 2010
We moved an Amana Fridge on it's side...how long should we wait before plugging it back in?
Anything with a compressor in it should always be left for 24 hours standing upright then you can plug it in
Mar 26, 2012 | Amana ABB1927DE Bottom Freezer...
One of my blades is stuck and I can't engage the release
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Bread dough beater will not come off
as far as possible.
Jul 17, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
I moved my computer. Hooked it back up and now the side speakers do not work. They power on but no sound . tried several connections. USB is plugged in and the green to green connection is in. checked all...
Hi
Please can you advise if you have 2 sound cards installed
You will know this by looking at the back of the computer, the sound card wil have 3 ports coloured Purple/Dark Green and Light green
Your speaker connection needs to go into the light green and will have a symbol above it like this ))(left arrow)
If there are 2 sets of ports then try one and if that fails try the other if there is only one plug your speaker conneciton into the light green port
Regards
Jan 31, 2010 | eMachines ET1641-02w (PT.NA60X.001) PC...
The plug hook up
if you are talking about a dryer, this is what to do
if you are changing a 3 prong to a 4 prong
as long as you have the white in the middle terminal the red and black can go on either sides.just make sure the white in the middle and the red is on the right or left. the green is ground so hook that up to a screw
if it is from 4 to 3, just make sure the middle of cord is in the middle
thanks
Sep 05, 2009 | Kenmore Dryers
Last night I moved my living room around and moved in a new computer desk. When I hooked everything up the monitor is now not receiving any signal. I have checked all the cords and have restarted. Other...
Open the side of your computer. The card that your monitor plugs into may have come loose. Carefully pull it from the slot (you may need to unscrew it first or remove a bracket that keeps it stable; plus there may be a lever at the back of the card you may need to pull on) and then plug it back in again. It is not uncommon for this card (called the video or graphics card) to come loose when being moved around.
Jun 07, 2009 | Generic Memory Compaq Presario SR1215CL by...
Gateway E-4200, Pentium III, Win XP, Nothing Showing On Monitor
The beeps are usually an error code meaning either the RAM or video card has went bad or are not properly seated. Leaving it out as you did could have caused the parts to come unseated when you moved the unit. Try reseating the RAM & video card and then retry booting. Hope this helps & please remember to rate my answer. Thanks.
Jan 10, 2009 | Gateway E-4200 Notebook
HP JBL Platinum Computer Speakers Logo
76 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
richie46
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
