Question about Ovens
Oven will not shut off alarm keeps going - Ovens
  • erc6 Aug 24, 2010
    Its a GE electric model JSP31GP
  • erc6 Aug 24, 2010
    It's a GE JSP31GOP3WH serial number HH129935Q
    The oven panel reads -F1- and the alarm keeps beeping.
    The buttons arenot responsive and the oven heat is on.
    The only way to stop the heat is to shut off the cricuit breaker.
    GE say that the F1 alert means electonic panel faul and that they no longer stock this controller.
    Is this true, and is there another source for this part?
    Thanks
  • 1,711 Answers
GE lists this fault code as a failed oven sensor it is the little metal rod that sticks into the oven cavity near the top of the oven cavity it is fairly easy to change 2 screws hold it in place and the wire connections can be accessed from the rear of the stove after the access panel has been removed hope this helps if please click accept and thank you These sensors are 50 to 60 dollars
Posted on Aug 24, 2010
  • Ovens Master
  • 3,083 Answers
It would help to have a make and model number, but I will give you general advice that may help. There may be a reset for the control panel, and if you google your make, model number, and something like "alarm won't turn off", you might get directed to an answer on the net. Otherwise, I would call customer support to see if they can help. You can google the make, then type support, and find the manufacturer's website.
Good luck, thanks for using FixYa, and hope this helps.
Oven keeps beaping and has a alarm symbol showing
Sounds like the timer was set and time is up, the issue is whichever model oven it is has a specific way to stop the alarm. Some just require a simple pressing "cancel" while others use a combination of buttons. I would try pressing either the arrow up or down, if not present just press the "timer" button, see if the alarm symbol changes or disappears
Nov 10, 2016 | Ovens
I can't use my oven it keeps turning off and my oven is beeping and the problem light is flashing how can I fix this so I can use my oven
Kenmore electric oven keeps shutting off.... ' Sears PartsDirect
www.searspartsdirect.com > Ask an Expert
Oct 15, 2010 - Kenmore electric oven keeps shutting off. ... Can't locate your model number? Use ... hi, i purchased and replaced my etc (#316455420) for kenmore electric range model # 790.9011.2010. i was ... How to use the site (3:58) ...
Frigidaire oven Bake functions randomly beep and shut off ...
Dec 25, 2015 | Ovens
The F1 error code is lite and alarm noise won't shut off. turned off breakers and the alarm stopped upon turning back on but F1 lite is lite.
With your model & Serial number you should be till able to order the EOC (Electronic oven control). But they are not cheap.
Mar 17, 2015 | Ovens
The oven keeps blinking F2 what does that mean
F2 Heating mode high temperature This alarm is activated when the ERC senses a runaway heat condition or when the temperature exceeds "runaway limits". The ERC will beep until the cancel or another function is selected. If the alarm repeats the F2 code check the oven sensor and wiring after first checking for a stuck relay. If alarm goes away verify the oven will complete a clean cycle without any type of failure.
Nov 25, 2010 | Dacor Ovens
The alarm turn on by itself when the oven is off, F2Code
Faulty signal that is going to the alarm driver to trigger off the alarm. The possible fault is the switching circuit, possible a leak in this semiconductor that is causing this issue.
You will need to go back to trace from the alarm buzzer backward to the driver. Since all other features are working fine, it can be only the faulty trigger.
Disconnect alarm if you think the fault is beyond you to avoid this annoying fault.
Helpful?
Aug 21, 2010 | Maytag CWG3100A Gas Single Oven
Problem with tappan wall mounted oven
yes, the problem is fixed thanks to repairclinic.com. those guys are awesome and there is no fee for their help. the repair parts are cheaper than anywhere else i've checked and the tech support is second to none.
Oct 11, 2008 | Ovens
F1 display and alarm will not shut off
hi there,
can you tell me the model # on your stove please?
Sep 13, 2008 | Maytag CWG3100A Gas Single Oven
Alarm won't shut off
did you try turning breaker off then on after 5 secs or clear cancel or stop
Dec 12, 2007 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
77 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
