Does anyone have a picture of the D52W14 internal wiring locations....I took out the board to replace the caps and forgot what wires go where....mainly the power cables that connect to the upper board from the lower left board...but a picture of all the wires would help.
  • 5,807 Answers
Before you put back the Board, check the Horizontal Output
Transistor that is connected on the Flyback transformer
for confirmation.
Is these the one you are having or similar?
here is the sample image:
A and C , should not be shorted , Deflection Board ( TL 010 )
It is the Collector and Emitter of the Transistors
Posted on Aug 24, 2010
My TV works fine with excellent sound and picture quality but the picture comes and goes?
Check all cable connections, if known to be good, then I would think it is a internal board issue. these boards some times crack connection from heat cycling, boards flex hot and cold.
Feb 02, 2016 | Element Electronics FLX3711B 37 in. LCD TV
I've Disconnected the Main Power Supply Board and unplugged a couple of connections, with one set has a blue and black wire and the other has a pink and tan wire. Forgot to mark wires prior to disassembly....
If I understand your question, they are lamp connectors for two lamps, there should be 4 connectors total for 4 lamps (2 lamps per assembly), on the circuit board should aslo have two pair of sockets, and it does not matter which plugs of the two set of plugs go into the set of the sockets. Or post the pictures.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 27, 2011 | Gateway FPD1960 19" Flat Panel LCD Monitor
Need a wiring scematic to locate the dm module to replace caps for the microprocessors. Had a power outage the other night now the power light on the front of the set just blinks. Can anyone help me?
You need pictorial to locate dm module in tv and to replace bad capacitors.
This Link will help you to locate dm module in tv and info about what are requirements to replace bad capacitors in dm board.
Hope this will help you.
Thanks.
Dec 29, 2010 | Televison & Video
My philips 42PF9431D/37 has a blinking Red light and won't be able to turn on. Please help
its your capasitors in your power supply board you can see other post for help. I took panel off mine and removed power supply board and took it to a electronic shop and fixed for $25. just note where wires replug back in. you can take a picture of how wires are plugged in for reference. if you kow about electronics you can replace them yourself for about $7 the two caps will cost about $2 and shipping...
May 17, 2010 | Televison & Video
Need to replace distributor on 99 honda civic lx
How do you install a distributor on a 1999 Honda Civic?
Feb 17, 2010 | 1999 Honda Civic
Dont know where an item should go
This is an internal speaker. Find the speaker pins on the mother board. Should be somewhat close to the front panel connections.
Mar 23, 2009 | Abit NF7-S V2 Motherboard
Rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
ProView PL716s U101 roasted
I would change the caps anyway, they're cheap. The IC's may be running hot trying to make up for the bad caps.
Jan 28, 2009 | Proview Computers & Internet
TV just shuts down, won't power up(D52W14)
Its located on the extreme left side of the chassis from behind and has a large red wire along with another wire coming out of it. You can get it for under 50 dollars at the following link and they provide free tech support on line so you can do the replacement yourself. heres the link
http://servicemanuals.vstore.ca/
May 12, 2008 | RCA HD56W66 56" HDTV
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
