Magicolor 2400w cartridge rotation does not work. All the lights were on indicating out of toner so I replaced the blue toner. THe printer cycles and goes to error. I cannot rotate the cartridges to replace the red and yellow.
  • Anonymous Mar 15, 2014
    every time toner indication showing...
    Genius:
  • 3,587 Answers
You need to calibrate and clean those printer toner cartridges, one at a time, unfortunately.
Posted on May 05, 2008
  • dr_kent
    dr_kent Sep 06, 2012
    How do I do that? :-)
When I start up printer after it rotates the toner cartridges the error light comes on and cannot be cleared . On my Windows computer it says there is no cyan toner cartridge. There is, of course.
Does it say Image Cartridge or toner. Is the cartridge third party if so replace with a real Minolta cart the machine do know info on the chip on the cartridge and reject them sometimes
Feb 19, 2011 | Minolta magicolor 2400W Laser Printer
The error light stays on
Hi
Try to open the blue cover and close it. Then press a few times the "rotate toner" button. After that powerswitch off and on, should run.
If it´s don´t worked, make sure you have every transport secure away from the cartridges.
The contact`s should be clean in Printer and on cartridges.
If still the same prob, start from first tip.
It´s worked by my 2400W feed new toner
hope it can fix your issue
Thanks for using Fixya
Mar 25, 2010 | Minolta magicolor 2400W Laser Printer
The ERROR light of my Minolta magicolor 2400W Laser Printer stays on. I have inserted a new drum and all the cartridges are full. What do I do?
It´s worked by my 2400W feed new toner.
Nov 25, 2009 | Minolta magicolor 2400W Laser Printer
Will the magicolor 2400w stop if one toner cartridge is empty . If yes can it be bypassed??
Removed each toner cartridge, shake it and replace it.
I don't know if this is the real fix but it worked for me at this time..
Sep 03, 2009 | Konica Minolta magicolor 2400 Laser...
QMS Minolta 2400W doesn't print
try lifting the drum assembly, at the back of the assembly there is a fuse. replace it. hope this helps
May 25, 2009 | Minolta magicolor 2400W Laser Printer
Magicolor 2400W error
This happens to me every few months, I have to do a VERY detailed cleaning of all toner sensors. The knowledgebase on KM's website is actually very good about walking you through which sensors to clean and pictures indicating where they are located. This has fixed me up every time. GOOD LUCK!
Jan 19, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Toner Not Installed - After replace black
pleas clean toner chip reader, remove pc drum and all toners, under the toner rack there is a 3 pin chip reader, use pressure air to clean it. if the new BK toner is not original, it will say only not genuine toner but will print.
Jun 23, 2008 | Konica Minolta magicolor 2400 Laser...
Rotate Toner Button Does not Work
How do you change four toner cartridges-Minolta 2400w Printer?
May 20, 2008 | Minolta magicolor 2400W Laser Printer
Rotate Toner Button and Replace Cartridge Messages
Hello
take out all toners and pc drum, use pressure air to clean chip reader under the toner rack (right side) also use some alcohol to clean chips on toners and reinstall.
Installing new black print cartridge
Manually Removing Toner for magicolor 2400W
1.  Hold down the Cancel button for 10 seconds or longer.
2.  With the Cancel button still held down, also simultaneously hold down the Rotate Toner button for 10 seconds or longer.
3.  When all LED indicators are blinking rapidly, release both the Cancel and Rotate Toner buttons.
4.  Then hold down the Rotate Toner button again for another 10 seconds or longer.
5.  The Cyan toner cartridge moves into the proper position, so it can be removed.
6.  Remove and/or replace the Toner Cartridge if necessary.
7.  Open and close the covers. Each time you do this, another toner cartridge moves into the proper position, so it can be removed and/or replaced (in this order: cyan, black, yellow, magenta).
The link is located here
Oct 21, 2007 | Minolta magicolor 2400W Laser Printer
149 people viewed this question
jasbo
jasbo
