Question about HP LaserJet 2840 All-In-One Printer
HP2840 All-In-One. Makes loud squealing noise when calibrating & printing. As if it needs oiling.
    Sniper:
  • 56 Answers
Thy taking the imaging drum out and power cycle. If the noise goes away replace it. If the noise persist it might be the carousel
Posted on Sep 08, 2010
My lexmark t652 is making a squealing noise when printing
Try with another cartridge first.
Printer may have gears with broken teeth.
Oiling will not help.
Nov 22, 2013 | Computers & Internet
After sitting in trafffic on the interstate for about 45 min, my 2006 4 cyl. mercury mariner began making a loud squealing/screaming/whining noise almost like a horn sound. the noise occurs at 0mph and...
Loud & Squealing -- sounds more like a belt or the pulleys
going bad,or alternator bearing
A hissing or other less squealing sound ---could be a
intake manifold gasket leak, but your engine would run lean
& set a MIL Lamp or Wrench on the dash
They is no value what so ever with an oil change jockeys
opinion,you need a local repair shop
Doubt anything is cracked
This is a social web site & as you know any prices come
from the merchants you deal with & only when they know
what has to be resolved
Working on vehicles or anything else is not a guessing
game & that is all we can do without the vehicle to test
Jun 13, 2011 | 2006 Mercury Mariner
Really loud whirring/squealing noise
Yes, It is still safe but very annoying...
The source is probably the guide rollers for the drum or the belt tensioner pulley. To know for sure you will need to pull the dryer apart and turn it by hand slowly and see where the noise is coming from...
Heatman101
Mar 03, 2010 | Whirlpool Dryers
Washing machine makes squealing noise during the
when belt was changed did you find the old belt to be oiley . it maybe leaking oil from trans . and the belt will keep failing till oil leak is corrected.. mm
Dec 14, 2009 | Washing Machines
Loud rumbling noise with slight vibration
Normally the noise you hear is caused by the drum rollers having flat spots on them or needing lubricant.
If this is what is wrong It will make a kind of thumping noise.
When they need lubricant they will normally make a squealing noise also. You would lube the shaft and bearing area of the roller, using a good machine oil...something like "3 in One" oil.
Sep 26, 2009 | GE DBXR463ED Electric Dryer
My HP psc 2210xi all-in-one printer makes loud noise & prints bad
It requires service as due to dust and dirt the gears are getting stuck, however if you can do it all it requires is a good cleaning and use machine lubricant to oil the iron rod on which the head moves.
May 05, 2009 | Office Equipment & Supplies
Craftsman Tiller makes loud, shrill, squealing noise when tilling
Noise comes and goes sound like metal on metal not a belt squealing
Apr 03, 2009 | Craftsman Garden
When engine fan engages makes loud squealing noise
Either tighten the fan/drive belt or replace it .. it is loose ...
Mar 22, 2009 | 2000 Mazda MPV
Dictaphone 2710 noise problem
This squealing noise is caused by the capstan motor. The bearings have dried up and it's metal on metal - causing an awful squealing noise. As soon as you put in a cassette, the motor begins to spin - causing the squealing noise.
Aug 11, 2008 | Dictaphone Audio Players & Recorders
Rainbow SE makes Squealing Noise when switching it On/Off
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=528929
Rainbow SE makes Squealing Noise when switching it...
Posted by ray_s51 on Apr 20, 2008
My Rainbow SE works and runs strong but when I switch it on and off for approx. 20 to 30 seconds the motor makes a loud squealing noise. Do I need to oil something or what? Nothing smells, it does not make the noise all the time, but it does more often than not. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum.
The Rainbow has 3 fans in the bottom of the motor and if they are weak they will make noise from the motor unit. Watch out… the repair of the Rainbow may exceed the cost of a new motor of which will solve your problem of noise and separator --- compare the cost and the labor and make a decision. The separator is part of the armature, the separator should be able to be removed and that might be one of the things making noise. As normal maintenance the separator should be removed and cleaned after every use and re-installed, then place a newspaper or towel under the motor unit and turn on the Rainbow and spin the moisture out of the motor unit. This should be done every time you use it. If you have further questions please feel free to contact your local vacuum cleaner dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Apr 20, 2008 | Rainbow E series Canister Wet/Dry Vacuum
HP LaserJet 2840 All-In-One Printer Logo
784 people viewed this question
Seeker5211
Seeker5211
