Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Our new Frigidaire side by side refrigerator/freezer is freezing meats and vegetables in the chill and crisper drawers. What are the proper temperatures to set the 'fridge and freezer at - the installers set the 'fridge at 37F and the freezer at OF.
  • Frigidaire Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
The meat and veg drawers freeze the meat and veggies no matter what setting the temp. is on.
Freezing meat,vegetables. Problem with damper.
For this problem, its indicating towards problem with damper assembly.----------
The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is remained open, its not closing.Due to this the cool air from freezer section is running in to fridge section non-stop.Due to this the vegetables and other food in the bottom drawer freezing.--------- In this problem the damper assembly needs to be replaced.---------------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 08, 2011 | Kenmore 56829 Side by Side Refrigerator
Vegetables freezing in crisper drawer
This is an issue with the convection system in the refrigerator, while the cold air trapped withing the crisper drawer remains and the temperature of the moisture in the area drops below the freezing point, the water content acts as a cover and thereafter enables the vegetables to freeze. A slight rearrangement of the utensils within the refrigerator solved the problem
Jan 21, 2011 | GE GSS22SGM Side by Side Refrigerator
The food in the refrigerator drawers (crisper and meat) are freezing and the waterline froze. What is causing this and is it worth repairing?
I have Ge GSS25XSQA SS side by side and the food in the refrigerator drawers (crisper and meat) are freezing. Also the ice dispenser is frozen closed. The water dispenser still works.
Want can I do to fix it. Would dirty coils have anything to do with this?
Terry
Nov 10, 2010 | GE GSS25SGPSS Side by Side Refrigerator
Crisper drawers are feezing vegetables.
look down at the bottom crisper and there should be an air control that lets more or less air in from the freezer section. close this control down so that most of the air stays in the freezer. some models may say meats(colder) and vegetables(warmer).
some models the control in the down position opens up the vent more allowing it to get colder and in the up position closes the vent down more allowing less cold air into the refrigerator. you can remove the crisper and experiment with the control.
Jul 14, 2010 | GE Profile¿ Arctica® Energy...
Water is not cooling
Hi: This Wide by side is like all other side by sides as to how it stores the water. Storage will be behind the crisper or meat keeper in the form of a coil of tubing or a bladder to store the water. Pretty simple. The length of tubing running from the storage to the dispenser will not be chilled. Some refrigerators do this better than others. Try setting the ref. or meat keeper a little colder. Watch your vegetables so they don't freeze. Rare, but it's possible... Older homes (before dispensers,) when fridges just had ice makers, would tap into the hot water line for ice to freeze faster and be clearer. I know this sounds crazy but it's true. I lived in an older home and in the winter the hot water would always freeze first. I know this solution sounds lame but there really is nothing much to go wrong with the water chilling. Pull your meat keeper out and look at the reservoir and see how cold it is. Good luck, Jeff
Jun 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
Amana Bx22s5W freezes food in the crispers
I've had the same issue with an Amana BX21TL. In my case, the problem was that the various air flow adjustments were all directing the cold air to the bottom of the fridge, underneath the vegetable crispers.
What I've done to fix this was:
1- Made sure there was a tight seal between the vent opening at the back of the fridge (at about mid-height) and the rubber/plastic duct that directs air to the meat/cheese drawer.
2- Made sure that the adjustable opening at the back of the meat/cheese drawer was fully open.
3- Made sure that the adjustable opening at the back of both vegetable crispers were fully open.
Hope this helps.
Jan 25, 2009 | Amana Refrigerators
Kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Amana bottom freezer model #BX21TW purchased in 1996
this particualr refrig is notorious for this. check your controls ( your freezer control as well set to 4 max) any higher and the refrig is running longer, generating more cold then needed, behind the left hand crisper is a few slots( the fresh air return) by default the coldest spot in refrig, i usuallly would reccomend to my cust not to keep high water or thin walled vegies in there such as carrots cukes tom and lettuce, perfect beer and fresh /frozen defrosting meat to be though, if you ever looked at the newest bottom freezers they've pushed up the drawers and added a deli pantry, running the width of frig
Feb 27, 2008 | Refrigerators
Bottom vegetable/fruit drawer freezing fruit
to the left of the bottom drawer is a veg/meat slide switch.make sure it is all the way on veg.if it is on meat,it opens a small doorway to the freezer and lets the cold air in and will freeze the food in the bottom drawer.in some cases,you will need to remove the drawer and shelf and then take apart the doorway.ball up some putty and jam it it the hole to completely seal it off
Jan 11, 2008 | Amana ARS2661BS Side by Side Refrigerator
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
273 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
