Question about Dishwashers
My kitchen and living room are combined and the more moderately priced dishwashers are more noisy. Can I pad the sides with something that will make the unit much quieter?
  • Dishwashers Master
  • 43,501 Answers
Yes!! you can wrpa some extra fuberglass insulation around them and it will make them quieter...
heatman101
Posted on Aug 24, 2010
Testimonial: "Sorry I asked a second time. Didn't realize that my first question posted. Thanks!"
PLS REG H/S on screen
Consult the owner's manual on how to register a handset with the base unit.
It usually means that you press a combination of buttons (see the handbook) until the phone stops display a message like "Range Out" or "Searching".
You may also need to name the handset so you know where it needs to be returned, like "living room", "kitchen", etc.
May 24, 2015 | Cell Phones
How much should i charge for painting a two bedroom apt. Inteior only. walls and cealing two bath one living room kitchen and laundry room
About 50 cents a square foot would be a reasonable price for a straightforward paint job (no stairs, cathedral ceilings or furniture to move).
May 28, 2014 | Measuring Tools & Sensors
Equlvalent expression
Assume that the room are rectangular.
Let W be the unknown width of the dining room in feet
Area of living room= 10*12=120 ft^2
Area of dining room =10*W
Combined area= sum of the two areas= (120 + 10* W) ft^2
Alternatively, you can factor out the 10 to get
Combined area =10*(12+W) ft^2
Mar 09, 2014 | Office Equipment & Supplies
My scanner works in one room and not another. However sometimes it does work. There is nothing new around it that would cause an interference in reception. Any ideas what the problem could be?
physical location and the fact both in one location have problems mean something is blocking or affecting signal---old joke: if you turn your head a certain way and it hurts--don't turn that way!
May 15, 2012 | Radio Communications
Should I buy a Bosch?
In my opinion, these do not live up to the Bosch name. They seem to come up on our radar here with "unusual" problems, and a lot of the questions posted go unanswered.
I replaced a beautiful stainless steel Kitchen Aid, after replacing the motor/impeller assembly because it was noisy, and the new one failed also. I bought a Samsung, and I like it. There a re several schools of thought about dishwashers, neither of them are very good, but here goes: One friend buys the brand name cheaper models. One buys only the higher end "best" types.
My best advice is to buy a brand with a high degree of reliability, and stay in the mid price range. The reason I say this is that the middle price range units generally have the better components of their "flagship" models, but don't have as many cycle choices, rack choices, etc.
GE, Whirlpool, (Samsung) are good brands. Frigidare is in there, too. I will never have another Kitchen Aid or a Maytag. I found them to be overpriced and unreliable, but this is just my opinion.
Best regards, --W/D--
Aug 11, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
MY VOLTAS VERTIS PLUS WINDOW AC IS VERY QUIET INSIDE THE ROOM BUT IS VERY NOISY OUTSIDE. IS THAT NORMAL? /
It is quiet inside that is normal. But outside also it should make reasonable moderate noise only. Check for any vibrations of wooden, glass, grill or plastic body. Check for balance. It should be tilted somewhat downwards.
May 06, 2009 | Samsung Heating & Cooling
GE Side-By-Side Refrigerator Model GSS 23QSTA SS
Apparently the digital read out sensor is bad. 45°F is to high for safe food storage. The fact that the milk spoils is another factor which speaks on its own that there is a temperature control problem. There is no "defroster fan". There are two fans in the unit. One is the air circulation fan located inside the freezer compartment and the other is the condenser fan for cooling the refrigeration system. If you had called for service in the first year it would be covered by warranty with the exception of the service call charge. After the first year ends electrical and control problems are not covered. If the evaporator fan in the freezer is noisy there is something wrong with it. It could be the source of your whole problem.
Mar 27, 2008 | GE Profile PSW26P Stainless Steel Side by...
Noisy
Our Bosch had a similar problem. I think something was stuck in the pump and causing the rattle. Remove the filter and clean out any gunk and/or water left in the sump. If your model is like mine, the pump cover is on the left and can be removed by unscrewing on Torx screw (I didn't have the right size torx wrench, but mine came out easily by turning it with needle-nose pliers). Lift the cover off and see if something in there is causing the rattle. Clean and reassemble
Oct 25, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
hdrubinpe Even if GE had denied the excessive noise issue, they definitely can not denied wrong temperature. Milk must stay in good condition till the expiration date on a bottle. Call GE for service. Gendos...post back
Feb 23, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Dishwashers Logo
43 people viewed this question
Top Dishwashers Experts
Owen Barnes
