Master
- Posted on Aug 27, 2010
Re: When trying to connect to the internet I get error...
Error
Code: 52230
There appears to be
an issue with your wireless router's firewall.
- It is possible that your Internet Service Provider (ISP) is not
compatible with the Wii console. For instance, if you need to login
with a user name and password when you try to go online for the
first time after restrarting your PC, your ISP is likely not
compatible. Please contact your service provider for more
information.
- If this error occurs regularly, while you are playing at home, it is
likely a connection problem related to your firewall settings. For more
information on firewalls, click here.
- Are you using a Netgear brand wireless router? Our expeirence
shows disabling the "SPI Firewall" of the router may
help the connection. The "SPI Firewall" option is typically found
under the "WAN Setup" tab of the router's settings. For
information on accessing your router's settings, please click
here and select the model of the
Netgear router you own (if available).
