Question about The Home Marketplace 70047 Waffle Maker
Vitantonio waffle maker
The top of the waffle doesn't cook as even as the bottom does and I want to remove the grids for cleaning.
  • Anonymous Mar 13, 2014
    waffles get brown on bottom while raw on top
  • 758 Answers
It sounds as if the iron isn't cooking at a high enough temperature. I'd try turning the iron to the highest setting, first (the thermostat may not be giving a correct reading, keeping the temp too low), before considering getting a new iron. The good news, though, is that a new waffle will only set you back about $20
Hope that helps
Please rate accordingly
Thank you
Computerrep
Posted on May 05, 2008
    Sergeant:
    Champion:
  • 347 Answers
to clean the waffler just use soap and wash the surface.
I dont think there is an easy way to remove the grids since they are placed on each plate tightly when they are made.
I also have a waffle that dosent cook evenly.
Next time you cook on it, make sure that the lid is closing completely. If it isnt,you will have tofind a way to make the lid close completely. ex. twisting some cables/screws that might me bend.
    Sergeant:
    Champion:
  • 329 Answers
Have you open your waffle? if you already open it, check if theres a cut to the wires of you your waffle or check if there is a lost tread on something. thanks!
Once the waffle is cooked how do you open the iron?
You need to spray oil on the waffle iron top and bottom before you put the batter in so it doesn't stick.
When it's cooked (steam mostly stops coming out), just lift the top off, and use a fork to lift your waffle out.
Aug 27, 2015 | Kitchen Appliances - Others
Need directios to use. waffle sticks to top and bottom
If it is a non stick waffle iron don't use a spray coating.
If it is a uncoated iron it is normal for them to stick for the first few uses. If you already have waffles stuck in the iron coat the stuck areas with cooking oil and reheat. Use a wooden or bamboo sewer to pick out the remains. Use cooking spray to coat the grids before cooking waffles. Try a different recipe. Some are more forgiving and don't stick as easily.
Jul 14, 2014 | Kitchen Appliances - Others
How to clean model 230
Probably not safe to put under running water. Water will get inside of the unit. You can scrub the grids with dry baking soda and a plastic brush or scrape out stuck waffle parts with a wooden stick or a bamboo chopstick. One trick to use is to add cooking oil to stuck parts and allow them to cook before trying to scrape waffle parts out.
Feb 15, 2014 | Toastmaster 200 Waffle Maker
I lost the instructions for my sunbeam waffle maker, and I dont know how long Ihave to bake it.
Here is a direct link to the User's Manual for your appliance:
http://dl.owneriq.net/d/db0acd4e-57c1-43f0-a51b-4ef04ad30e2d.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 2 of the manual for detailed operating instructions. Basically they read as follows:
Preparing Waffles
1. Close Waffle Maker and plug into outlet. Use only voltage specified on bottom of Waffle Maker. The Power light (Red) and Ready light (Green) will come on.
Caution: Touch Waffle Maker only by handles during use or directly after use. Take care not to touch hot surfaces.
2. The Waffle Maker is ready for initial use when the Ready (green) light goes out (approximately 2-4 minutes).
3. Open Waffle Maker, pour approximately 3/4 cup waffle batter onto grids. For best results, pour batter around outer edge of waffle maker. Close cover. It is very typical to have a small amount of batter run over grid and down Waffle Maker. However, if an excessive amount of batter runs over, use less batter.
4. Close the Waffle Maker by lowering the upper plate onto the lower plate and secure with the safety latch. Do not open cover while steam is escaping. Most waffles bake in approximately 2-4 minutes, depending on personal taste. Waffles are generally done when the Ready light (green) goes out and when steam no longer escapes from sides and front of Waffle Maker.
5. When waffles are done, remove with a fork or wooden tongs. Note: Be careful you do not scratch the non-stick cooking surface.
6. Close cover and wait for Ready light to go out before preparing another batch of waffles. The next waffle may be baked in less time because the plate will store heat.
I hope that was helpful to you, good luck and take care.
Joe.
Aug 31, 2011 | Sunbeam 3852 Waffle Maker
I have a pre owned wm-4. No owner's manual. Can the plates be removed for cleaning?
These instructions are taken from a WM14 waffle maker, maybe they will work for you. It doesn't say anything about removing the plates:
"Wipe Cooking Plates with absorbent paper
towel or a soft cloth. Although the Cooking Plates are coated
with a non-stick coating, some batter or ingredients may still adhere
to the Waffle Maker. To remove, simply pour a little cooking oil onto
the baked-on food. Allow to stand for 5 to 10 minutes. This should
soften the food and make it easy to remove with absorbent paper
towel or a soft cloth. If the preceding measure fails to remove the
food residue, we suggest wiping the Cooking Plates with a slightly
dampened cloth and a little non-abrasive detergent."
Mar 28, 2011 | Salton WM4 Waffle Maker
Waffles are separating when we open the plates
In my experience this is due to sticking on the plates. I spray a little cooking spray on them with each batch I make.
Maybe they arn't quite done.
Jul 12, 2009 | Waring WW150 Waffle Maker
Waffle Iron Sticking...HELP
Try using 2 Tablespoons of oil in your recipe.
Mar 21, 2009 | Kitchen Appliances - Others
CLEANING THE TOASTMASTER WAFFLE MAKER
If the plate are not removable, clean with soapy rag. Otherwise remove and clean with warm soapy water. After drying, re-oil with light coat of cooking or olive oil.
Mar 08, 2009 | Toastmaster 234 Waffle Maker
Seasoning Waffle Baker and Grill
FIrst, make sure there is some kind of fat or oil in the waffle batter recipe. This is the biggest difference between waffle and pancake batter. Go to Sams or a restaurant supply store and get a spray product like waffle-off. Spray lightly aftter every few waffles. Use lightly as heavy spray can cause build up. If you can't find this product use one of the PAM type sprays for BBQ grills or maybe an olive oil based product. Regular Pam sprays build up faster as they are not really designed for this. Don't try to wash the grids between uses as they need to keep the oil coating. (Like using a cast iron skillet) They will turn a dark brown. Just brush off crumbs or use a damp rag. Make sure the waffles are completely cooked as when not completely cooked they will seperate and be very difficult to remove. They are cooked when the steam stops coming from the sides. This will take 3 - 6 minutes. Don't preheat with the iron open or allow it to stand open for any longer than necessary. (It can overheat)
Apr 13, 2008 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
1,098 people viewed this question
Top The Home Marketplace Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a The Home Marketplace Kitchen Appliances - Other Expert? Answer questions, earn points and help others
