Question about Kenmore 85871 Electric Dryer
Kenmore dryer HE2
Stops then starts flashing F22
  • agarcia2222 Jan 12, 2009
    same problem, but for a he3t electric dryer what does that mean?
  • Anonymous Jan 30, 2009
    he3 gas drayer F23 problem
My kenmore he2 gas dryer runs for 2 or 3 minutes the shuts off, flashing an f22 error code
Posted on Sep 20, 2008
  • wayneminton Sep 17, 2010
    on your HE2 dryer I have the same problem. What did and what does F22 mean?
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Our he2 dryer is flashing a F
Get online ask Kenmore.Did u lose book?
Aug 12, 2012 | Kenmore HE2 Plus Front Load Washer
My HE2 front loader dryer flashes f22 and stops. A repair man has replaced the thermistor twice, but it is still flashing the same error.
This means the outlet thermistor, the one on the blower housing, is open. But since the thermistor has been replaced twice and the error code still flashes (make sure it is cleared after the replacement by pressing STOP twice), the wire harness (including the connectors) connecting it to the electronic control board is cut open or the electronic control board itself is faulty and not detecting the thermistor connected.
Check the connections and the continuity of the wire harness and replace or repair it if found cut open. Consider a faulty electronic control board if the wire harness and the connectors are intact and the thermistor is known to be 100% good. Normal thermistor resistance is around 8500 ohms to 13500 ohms at room temperature (27-21 degrees centigrade).
Mar 09, 2011 | Kenmore Elite HE4 Electric Dryer
DRYER DISPLAYS CODE F22. What does this mean?
"F22" is a door lock issue Press the "Stop" button twice to cancel the cycle if "F22" shows. Check that the washer door is firmly shut--open it and shut it and try again. Make sure there aren't items blocking the closing of the door. Don't overload the basket. Try the cycle again.
Nov 25, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore HE2 desn't stay running and F22 errror shows
refer to the owners manual to learn what these error messeges mean
Sep 17, 2010 | Kenmore 85871 Electric Dryer
Kenmore he2 dryer when pushing the start button, it will click and then the digital readout flasshes an F then it flashes 26 got any ideas?
PRESS STOP OPEN DOOR PRESS BLACK BUTTON MIDDLE OF MACHINE ABOVE THE LACTH U WILL HEAR A CLICK THAT RESOLVE THE SITUATION
Aug 19, 2009 | Dryers
Error codes "f1" "f22" etc. and washer stops at different times
Replace water inlet valve or clean water inlet screens. Remove the water inlet hoses and take a look see. Just guessing.
Jun 14, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Gas Dryer Control Panel Does Not Work Properly
I have the same problem..really disappointed in this product. I bought mine in 07 as well..I found that if i hold all the buttons down and then hit start it (Sometimes starts), but after it starts it turns off after 10 seconds.
Mar 27, 2009 | Kenmore Dryers
Kenmore He5 dryer, a service code f22
just remember error codes are always going to be stored on every machine ,, shoukd not have a problem ,, but does it work
Nov 29, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore front loader HE2
F22 Error means
DOOR LOCK ERROR
after 6 failed attemts to lock the door.
Possible Causes/ Procedure 1.-*Door lock mechanism is broken or removed from door. 2.-Door  switch/ lock unit failure. Check door switch/ tock unit. 3.- Check the wire harness connection to the door switch / lock unit and Central Control Unit (CCU).
was this helpful?
May 05, 2008 | Kenmore 82836 Gas Dryer
Kenmore 85871 Electric Dryer Logo
1,203 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
